THE WOODRAT IS BACK!
DIY adjustabench in wood- what do you think?
ThomD
>I was just wondering how people feel about the Adjustabench, and whether there is any interest if there was a way of making one for oneself? The manufactured one would suit me save for three things: too expensive given my circumstances (though I think it is a pretty good value); distribution is not that great internationally; and the available width isn't as narrow as I want for the use I have in mind (though the right width for most I would imagine).
I thought of fabbing one out of metal but it looked like a dreary job for a one-off. So the idea of making one some easier way has been parked in my mind for a while. About a week ago I had the eureka moment I think I have two designs that will work really well, and allow "all wood" manufacture, from crude 2x nailing through to the nicer look one associates with a classic bench. Have full or improved functionality.
It is the sort of thing that would lend itself to a package of parts for folks who don't want to handle the fiddly bits, or even some major components, like LV does with their bench legs. The only problem is that while the design is all new, the operating principle (self locks when moved from either end) is the same as Adjustabench, and both magazine and manufacturers tend to avoid that kind of thing. So I don't know if a new design would get much push.
As far as my interest is concerned I will get around to it when I get around to it. I already have too many benches in my shop. Not much shop left. I am a convert to adjustable benches, however. I have several material carts and lifts that are adjustable height, and increasingly they seem like the go-to surfaces for any job that will fit on them. I was just wondering what other people feel about adjustable benches, and whether there is any interest?
Re: DIY adjustabench in wood- what do you think?
Pam Niedermayer, Austin, TX
>I'd certainly like to see what you come up with, having failed to come up with anything that might work myself. :)
Pam
ThomD
>Sure Pam. Not much interest from the look of things, may try cross posting on the main board.
Re: DIY adjustabench Some good vids
ThomD
>http://videos.americanwoodworker.com/video/Adjustable-Height-Woodworking-B
http://jack-bench.com/workbench%20plans%20-%20how%20it%20works.htm
>Interesting. The first bench is more along the lines I was thinking, like its simplicity, and if one can due with a more modest amount of travel it should work quite nicely.
The second, torsion boxes and scissors, hardly need be made of wood at all, what with all the mechanical stuff, would be very expensive to build.
The only thing I've come up with so far is a nested leg arrangement with pegs every inch or two, hollow legs on the base with solid legs on the top.
Pam
>I saw, somewhere - old Fine Woodworking in the black and white days? - a bench that used the nested approach.
It strikes me that you're inevitably building in some slop this way. You couldn't run boards from leg to leg that attached directly to the top - you could on the "receiver" portion at the bottom, but the top is then not attached directly to those, so you could get some wiggle in the benchtop.
It would be an interesting thing to make and test out.
>Yeah, I don't think it would be satisfactory in practice unless I could find huge pieces of something like desert ironwood, but it was the best I came up with. :)
Pam
Nothing but air
Bob Hackett
>Seems like there`s more than normal industrial debris at the "transfer facility"(dump) lately.The local hospital has been tossing stuff left and right(scored a working vac pump) and I was thinking about using parts from a hospital bed to make a lift/bench.My brother the surgeon has a way cool OR table he uses for an assembly table/aux. bench that even tilts so...
Then I came across some sort of pneumatic machine from a factory that included 1 large and 6 smaller air cylinders and a multi function air pedal control,just the ticket for an air only bench.My current plan is to use the large cylinder to raise and lower and 4 of the small cylinders to clamp the legs for stability.The pedal will control all this and more.Who knows,maybe I`ll use the remaining 2 cylinders as either clamps or vice actuators.
MB
Powered, I presume - this being a hand tool forum-
>by a cadre of Newfoundlands working bellows - well, actually, Newfoundlands could generate quite a bit of air pressure just by breathing into the tubing.
Re: Powered, I presume - this being a hand tool fo
ThomD
>"by a cadre of Newfoundlands working bellows - well, actually, Newfoundlands could generate quite a bit of air pressure just by breathing into the tubing."
From either end...
Most of these designs use the weight of the bench to clamp the parts together, so that there is minimal shifting. The only problem there is getting the forces in both directions which some seem to do with fit, the tressle bench possibly gets some bang from the V sections.
I doubt the hardware is all that expensive in the jacks bench, Jacks are so cheap these days in various forms from places like Harbor freight. And I suppose scissor jacks are virtually free at a wreckers. I don't like the need to clamp the parts together, or the obstructions in the base access, but it is probably heck for stout.
