Pliers with protective jaws
Wiley Horne--So. Calif.
>Hi Folks,
There's a problem that comes up about twice a year for me. I find a way around it, and then promptly forget about it. Usually. But this time, I'd like to do something about it.
The problem is that I need pliers with protective (non-marring) jaws, sometimes needlenose for small things, sometimes a big crescent wrench or pipe wrench for plumbing stuff.
Anybody else have this issue? What do you do? What's the product that solves this once and for all, without masking tape, etc.?
Thanks,
Wiley
Re: Pliers with protective jaws
>Electrical tape is my solution, although it's a slippy solution - hard to turn things.
For needlenose pliers, you could get some shrink wrap tubing the right size, shrink it to fit, and then (probably) slide it off afterward. Then you'd just have to remember where you stored it the next time you needed it.
There are smooth-jawed pliers available in both needlenose and channellock type, designed for cases where you don't want to bung up the work. Whether this is worth the investment or not would be your call.
As for pipe, if you mean threaded pipe like galvanized or black iron pipe, there are inside pipe wrenches available that will bung up the inside a bit but leave the outside unmarred.
Copper
Bob Hackett
>You can either wrap the work in copper or the jaws.
Either way copper usually has just enough grab to still turn whatever you`re working on.Pretty much everybody has copper pipe laying around don`t they?
MB
Bicycle innertubes
Paul M.
>I have a large pile of punctured tubes from my mountain bike. I never throw them away. Some of the uses:
1) Wrap around objects you don't want marred with pliers
2) Clamp irregular objects (chairs and guitar bodies) while gluing
3) Cut off little rings and use instead of "space balls" in the grooves for floating panel doors
Re: Copper
ThomD
>They sell adhessive backed copper in places like stained glass suppliers in case you have one in your area. Adhessive backed aluminum tape is in every hardware. The classic solution is lead. And yes, I do feel so dirty for even having mentioned it.
Cable Connector . . .
steve mackay
>"Back-in-the-Day" we had a whole set in the Special Weapons tool kit for cable connectors. Adjustable jaws with replacable, teflon jaw inserts. They never appeared to be anything "custom" (like the $700 hammers) so I'd figure they could be had by the Common Man.
Tony Z.
>I bought a pair from MSC. Looking through the LV catalog, I saw the identical pliers there. They are "Channel-lock" type (water pump??) with a plastic/nylon jaw covering.
>Thanks Tony! And thanks to all. I just ordered the large and small Japanese-made channel-lock pliers from Lee Valley.
Will use other folks methods for long nose.
Thanks to all!
Wiley
Tony Z.
>Over the next few LV orders, try to remember to buy a set of spare jaw covers. These tear up pretty easy, although I have to get to the place where mine need replaced. These channel-lock style will get used for far more things than you imagine.
T.Z.
Parallel action pliers, et al *LINK*
David Barnett - SW FL Gulf Coast
>Often, especially when working on flat and softer materials, the problem is the angular compression of standard-jaw pliers. While copper, as Bob H. suggests (and my favorite for sheer gripping power - vise jaws, too), nylon or brass can improve things, the tool I most reach for: parallel plies, lined or otherwise.
They are offered in several widths and tapers, flatnose or chainnose, grip firmly and eliminate pinch distortion. I don't know how I'd get along without them, whether for jewelry or toolmaking.
Made-in-England Maun are the best but cost twice as much as the newer Valor pliers, which are pretty good (see link). Rubber cement helps to hold soft jaws in place and is easily removed.
Glass-breaking pliers for the larger stuff work nicely. Stained glass suppliers carry these.
Many metalforming pliers have nylon jaws, but these are often too thick for my needs, so I often line jaws with thin goatskin (workgloves are a good source). To avoid scratches on very soft materials (fine silver, high-karat golds, soft plastics). silicone tape is good, and silicone glue/caulk for glass and tile can makes custom-shaped jaws (best use cheap stainless steel pliers as the acetic acid can bite high-carbon). Another tip is to lightly radius and polish the edges of plier jaws.
It's rare that I reach for serrated pliers unless they're Vise-Grips.
Contenti carries Valor and Maun brands
Bill Lowrance in France
>For smaller pliers down through fine needlenose, tough flexible plastic tubing (lab, winemaking...) can work well. Thickness needed obviously involves trading off between "feel" and toughness. Some kinds have high surface grip, which can be an advantage. Cheap and trivial to replace.
Hey, thats pretty good . . .
steve mackay
>I've got to remember THAT one !
WOW! And to think...
Scott Burr in Ben Lomond CA
>I used the 3/8" tubing to make an extension for my turkey baster when I BBQ the Thanksgiving bird. Goes right through the grate of the 'ol trusty Webber right down to the drip pan. Hey it's almost time to do it again!
Scott, missing prime rib due to some vegetarians this year.
The collective genius of this board is incredible
Victor Parisian
Victor Parisian
>Where was all this genius when I was into bicycles. Campy Record bits and Vice-Grips don't play so well together (ouch).
Victor - Older & Wiser in Houston
