Grinding *LINK*
Grinding *LINK*
Grinding *LINK*
woodburnbob
>I inadvertently wound up at the site below during a little research on something else. Kinda interesting. All that follows is quoted the 1914 book linked at the bottom.
The Grindstone.�As most of the tools require a grindstone for sharpening purposes, an illustration is given as a guide, with a diagram to show the proper grinding angle. In Fig. 16 the upright [Pg 23] (A) of the frame serves as a line for the eye, so that if the point of the tool is brought to the sight line, and the tool (C) held level, you will always be able to maintain the correct angle. There is no objection to providing a rest, for instance, like the cross bars (D, D), but the artisan disdains such contrivances, and he usually avoids them for two reasons: First, because habit enables him to hold the tool horizontally; and, second, by holding the tool firmly in the hand he has better control of it. There is only one thing which can be said in favor of a rest, and [Pg 24] that is, the stone may be kept truer circumferentially, as all stones have soft spots or sides.
In the Use of Grindstones.�There are certain things to avoid and to observe in the use of stones. Never use one spot on the stone, however narrow the tool may be. Always move the tool from side to side. Never grind a set of narrow tools successively. If you have chisels to grind intersperse their grinding with plane bits, hatchet or other broad cutting tools, so as to prevent the stone from having grooves therein. Never use a tool on a stone unless you have water in the tray.
Fig. 17. Correct.
Fig. 18. Incorrect.
Correct Way to Hold Tool for Grinding.�There is a correct way to hold each tool; see illustration (Fig. 17). The left hand should grasp the tool firmly, near the sharp edge, as shown, and the right hand should loosely hold the tool behind [Pg 25] the left hand. There is a reason for this which will be apparent after you grind a few tools. The firm grasp of the left hand gives you absolute control of the blade, so it cannot turn, and when inequalities appear in the grindstone, the rigid hold will prevent the blade from turning, and thus enable you to correct the inequalities of the stone. Bear in mind, the stone should be taken care of just as much as the tools. An experienced workman is known by the condition of his tools, and the grindstone is the best friend he has among his tools.
Incorrect Way to Hold Tool for Grinding.�The incorrect way of holding a tool is shown in Fig. 18. This, I presume, is the universal way in which the novice takes the tool. It is wrong for the reason that the thumbs of both hands are on top of the blade, and they serve as pivots on which the tool may turn. The result is that the corners of the tool will dig into the stone to a greater or less degree, particularly if it has a narrow blade, like a chisel.
Try the experiment of grinding a quarter-inch chisel by holding it the incorrect way; and then grasp it firmly with the left hand, and you will at once see the difference.
The left hand serves both as a vise and as a [Pg 26] fulcrum, whereas the right hand controls the angle of the tool.
Carpentry for Boys
Re: Grinding *LINK*
Re: Grinding
Dean J in MN
>That is one reason I've always liked the idea of a large old wheel, the tool rest and blade are just horizontal. You vary your grind angle by where you present the blade to the wheel. I suppose one could take the guards off a modern grinder, but I'm not going to suggest it! :)
Fun stuff!
-Dean
