Thanks for George Frank tip
Bill Tindall, E.TN
>Someone down below mentioned a book by George Frank. Got a copy for a dollar off "half.com" which appealed to my frugal nature. I could not put it down until I read it to the end. Perhaps more a memoir on Frank's experience as a finisher than a "how to book", never-the-less I found it inspiring. I liked his down to earth approach to and description of finishing
Twice he mentioned using stiff brushes, in one case for smoothing shellac on moldings and in another using a wire brush for removing hide glue from veneer pores. In neither case was it clear to me how to use the brush to successfully achieve the result. The lengthy section on French Polishing was informative and very different than what is practiced by others who I have heard describe the technique. The stain recipe's were also informative.
I was not smitten by the oaks in primary colors and bright French Polished finish, but I have done ash in primary colors and finished with dull top coat and found the result attractive for certain kinds of pieces.
Re: Thanks for George Frank tip
Blue Vitriol?
charlie belden
>Like patina formulas for color jewelry, the ingredients in many of the finishes formulas sure sound like something an alchemist or wizard would use. I looked for "eye of newt" and "toe of frog" in the ingredients list - but didn't spot them - thankfully. They are apparently not something easily found, much less to purchase, these days.
The idea of using concentrated nitric or sulfuric acid or lye - in a one man shop?
Must've been a very interesting time - when folks were willing to try all sorts of 'crazy" ways of finishing wood. You have to wonder what the affects of all the chemicals they were playing with had on their life expectancy.
Felt hat makers used to use mercury in their hat making process. Mercury fumes breathed, or merecury absorbed through the skin has all kinds of undesirable affects on organs - like the brain. Hence the origin of the phrase Mad As A Hatter.
Good book.
Re: Blue Vitriol?
Glenn Madsen---in SF Bay Area
>When I was growing up in the 50's and 60's, I knew a family of house painters. These folks were using all sorts of chemicals in their work. Unfortunately, they also had a predisposition towards alcohol. Those boys that continued the work all died young and in pretty tough shape.
There was a lot of what now seems pretty strange to us stuff used back then...
Eye of salamander's easy enough around here
>where they grow wild. Just turn over rocks in certain areas. It's awfully hard on the salamanders, though, so it's better to seek out formulae using other ingredients.
It's amazing reading the old literature and seeing references to the casual use of chemicals that we now understand to be highly hazardous. Reading about dry-grinding white and red lead for paint mixing always makes my toes curl.
And it's not all that long ago, either. When we cleaned out my uncle's garage a decade or so ago, we found a jar of mercury, about a quart. Everyone kind of backed away slowly. I was glad that my cousin volunteered to dispose of it; although our local hazmat sites are convenient, I wasn't looking forward to a two-hour drive on California roads (rough) with California drivers (surveys have found that 47% of California drivers are completely insane when behind the wheel - no, no, I made that up, but there are some, um, poor drivers out there), with a jug of mercury sloshing around in the truck.
what a waste....
Bill Tindall, E.TN
>The mercury should have been taken to a college chemistry lab after withholding some for at-home experiments. I used to turn pennies into "silver" by dipping them in mercury and then dupe classmates into paying silver prices for them. Not sure what happened to my pint of mercury but I wish I still had it. Casual contact with the liquid is not a problem. But I would not want a quart spilled in my car.
Frank's hazzards- chromate noteworthy
Bill Tindall, E.TN
>The only ingredient in Frank's book that merits particular concern is potassium chromate. It is a known carcinogen when inhaled. When it reacts with wood it becomes a relatively harmless form of chromium. However, I did some experiments and significant amounts of unreacted chromate still remain after treatment of mahogany with chromate. The next step is sanding the wood back smooth which looks like an opportunity to breathe chromate laden wood dust.
Chromate is still used by many period furniture shops. I have encountered two recently. It makes a wonderful color on mahogany. However, this color can be approximated with water soluble dyes. I like it less so on cherry and walnut.
It would not be difficult to use the acids and bases he mentions safely in the shop. Of those lye is the most worrisome as it will cause blindness upon eye contact if it is concentrated. Its color on mahogany is not lightfast so there would seem to be little need to use it.
I dip sheep feet in a solution of blue vitriol to knock out foot rot. It stains wool green. It is easy to find in ag stores as I think it is used as a fungicide.
1 qt. mercury is more than $5000 worth
Bill Tindall, E.TN
>Should anyone else find a quart put it in a stout plastic jug and send it to me. I'll pay the postage.
Re: 1 qt. mercury is more than $5000 worth
Mike in Suffolk Virginia
>I have about 12 lbs of the stuff, which I believe is about a pint. What should I do with it?
Mike is Suffolk, VA
Natural Dying - and dangerous mordants
charlie belden
>First wife was into spinning and weaving - all "natural". We're talking raw sheared sheep wool - with burs and dingleberries and all. Had bags of dried flower petals, walnut shells and bark - all sorts of "natural dyes".
But to prepare the natural wool for natural dying - it had to be soaked in a "mordant" to get the scale like layers to "open up" so the dye could get in the space,
Moradnts - sulfuric acid, and one that got MY attention - Potassium Dichromate. She'd been pouring this stuff down the drain for months and months before I found out what she was using.
I wouldn't want to have that "natural dyed" stuff anywhere near my skin.
