A little fun with dovetails
>I was asked the size of my smallest dovetail chisel. It is a Japanese Iyoroi 1/16�. And, yes, it does get used �
Shortly before Veritas were about to launch the mini shoulder plane, Rob Lee sent me one for comment. Knowing Rob's enjoyment of practical jokes � just look at the history of Lee Valley�s April Fools tools � I came up with an idea of my own � to make a box for the shoulder plane.
First I prepared the 1/8" thick boards by hand .. USA Mesquite and Tasmanian Oak.
Sawing the tails (yes, with the 20 tpi Veritas saw) was not particularly difficult, and the waste was so small that it was removed with a single push on the 1/16� dovetail chisel (seen in the picture after the next). However, transferring the tails to the pin board was another story �
It turned out OK �
The box itself came together successfully. I added pieces at each end (just careful marking and planing, then glued), and sawed it apart for a lid.
Here is the box with the shoulder plane .. 3" x 1 1/4"
And a last picture for perspective ..
Fun, isn�t it? :)
So what is the smallest dovetail chisel you have used?
Derek Cohen
Re: A little fun with dovetails
Stephen Shepherd
Stephen Shepherd
>I have a 1/16" chisel I made from a broken needle file mounted in a dogwood handle. I actually use it for small mortises and dovetails when my 1/8" mortise chisel and 1/8" bevel edge chisel are too large.
I also have an 1/8" chisel (Two Cherries) that I use more often than the others as it is tanged and the other two have sockets, making them very long, heavy and not balanced like the tang chisel.
Somewhere in my collection is a double blade fish tail chisel I made that cuts a 1/16" wide slot by 1/2" long.
Stephen
Cute. Very cute. Got to try one for mine.
Victor Parisian
Huh?
Pam Niedermayer, Austin, TX
I understand the components of the sentence quoted, but am befuddled by this sentence. What's a double bladed chisel? I know what fish tail means, but never think of chisels cutting rectangles (wide by long). How about a photo?
Pam
>I've used a 1/16" Japanese chisel that I bought from LV some years ago, although it's width varied a bit due to hand forging, it's somewhere around 2 mm. However, it's a chisel I often used for making tiny dovetails and grooves in tiny drawers I made for practice some years ago, but it's not what I'd call a dovetail chisel.
The smallest chisel(s) I've used are 1 mm or so from a set of Dastras.
Pam
Wow - 1mm is almost a knife.
Re: Wow - 1mm is almost a knife.
>Nah, but they break like edges. You have to be very gentle when using and sharpening.
Pam
Consider An Engraving Graver
charlie belden
>For tight spots, especially the bottom corners of tail, a small engraving tool works pretty nicely - and they're short, usually with a mushroom handle so you're not waving around 8 or 10 inches of tool. Very quick to touch up the edge or sharpen since there is very little cross section to work on. Keeping things oriented properly is tricky - but engravers have a sharpening jig for that - which works really well - on smaller tools - up to maybe a quarter inch wide.
Stephen Shepherd
Re: Huh?
Stephen Shepherd
>Pam,
Here is a drawing of the tool, it is the one on the right upper corner, Double Cut Mortise chisel. Start by drilling a relief hole then pound the chisel down.
Stephen
something new to learn every day
>that's neat. It seems like a production tool - specific design for a specific mortise.
Flat gravers are what I've used
David Barnett - SW FL Gulf Coast
>But for woodworking you relieve the business end about 3/4" or so on a grinding wheel and then grind to a triangular shape similar to my Japanese 1/8" DT chisel, as the bevels on most flat gravers thicken (slope wider) from the belly upward. 1.5mm is about 1/16" but they go down to about 0.2mm for a #36 flat graver, which is close to 1/128". You'd have to be cutting some fairly fine DTs to need that one. I have two #47s ground left & right skew that are pretty handy on the rare occasions I've needed them.
Stephen Shepherd
Re: something new to learn every day
Stephen Shepherd
>I don't know the German word for fish iron but that is what this chisel is call. It is used for mortising the leaves of a hinge into a cabinet and door.
Stephen
Clarify, please? *LINK*
>Do you mean that there were historical hinges like the modern ones (link below to one example of the modern ones I'm thinking of), on which the leaves were placed vertically in a mortise, rather than screwed on a gain on the surface or edge of the cabinet/door? Were these "stab" hinges like the modern ones, held in by tangs, or were they then pinned or screwed in place too?
Modern ones are pretty lightweight
Stephen Shepherd
Re: Clarify, please?
Stephen Shepherd
>Bill,
I think the modern ones copied the old ones, but the idea is the same. The older ones I have seen on European furniture are heavy duty, some have fancy finials on the barrel, some are simple butt hinges.
The slot is chopped with the chisel, and there is usually blow out on the back side, not seen. The hinges are inserted and usually nailed through the wood then through the screw holes, then the wood again.
Stephen
Thanks - I keep learning a lot here
Re: A little fun with dovetails *LINK*
Andrew F in Australia
>Hi Derek,
Probably these ones. I think you've seen them already. I gave the drawer to Chris Vesper - Don't know if he uses it for marketing or no.
Cheers,
Andrew F ('eddie the eagle' on the other forum')
Dovetailed matchbox
>Hi Andrew
Your dovetails were definitely the best in the "smallest dovetail" competition. Really amazing! I just cannot see that small to control a chisel that carefully. What did you use?
Mine were not as pretty (pretty rough - but I only took a few minutes with the sawing) however they were the smallest (excluding the use of store-bought veneer, which I think is a cheat) - 1/32"
Link below.
Entry for "smallest dovetailed box" competition
>Hi Derek,
I used a skewer (1/16" chisel) and a hacksaw blade that I snapped in two, ground a bevel onto and then used this for the detail work. I suppose that makes it a 0.8mm chisel.
CHeers from someone frantically getting ready to take a group of schoolkids out on a two day Duke of Edinburgh hike in 8 hours. Sorry for the short reply,
Andrew
