The new MK2 Ashley Isles chisels
Patrick Gibbons, Katy, TX`
>I got one of the new MK2 chisels with the smaller handle and thinner edges on the beveled sides. The thinner edge is nice but it's the sizing of the chisel along with the smaller handle that make these sweet. I also like the concavity in the back of the chisel. Sharpening is easy and, like all other chisels, the edge gets sweeter the more it is sharpened and used. The three largest chisels have the larger handle that all the AI bench chisels used to come with. While they do not feel mismatched, I find my Greenlee 1 1/2" socket chisel with a smaller handle feels better balanced. However, my 2" AI chisel (old style) feels just right with the larger handle and has always been my favorite to use. I have the 1/8" AI butt chisel and the new sized handle still feels better balanced with the longer steel than the butt chisel with its yet smaller handle does. I also like the fact that the steel is old-school tool steel and takes less time sharpening. I have found the AI chisels are brittle when first used. It takes a few sharpenings for this brittleness to subside and the steel to "settle down" to holding an edge longer. A steeper microbevel seems to help also. While I'm glad AI has gotten their bench chisels right, I'm upset over the notion of having to replace the ones I have now. The longer-handled chisels are good for paring and there's not much incentive to replace the largest three sizes which retain the longer handle in the new style. But the new MK2 chisels that are 1" or less in width are a definite improvement over the old style for an all around chisel.
Re: The new MK2 Ashley Isles chisels
Mike Bridger
>Yesterday,I sawed about and inch and a quarter off the butt ends of my three "long-handled" AI's. Rounded and smoothed - problem solved. Now they feel just right. I still need a couple of sizes and will be ordering the MK2's.
Tony Z.
>If you have a lathe with a bore through the head large enough, simply chuck the blade edge side of the chisel (on the ferule), support the other end of the chisel with your live center (tail stock) and turn the handle to your liking. I've done this with my AI's and also with a set of Narex. Simply amazing how much more you use a tool after customizing it to fit your hand.
>I'm thinking I might do the same thing. However, the blade beveling and concavity of the back on the new MK2'S are just sweet. There's no other word for it.
Handle update
>I just shortened the handle on my 1/4" chisel with my Jet mini lathe and it's a success. The 3/8" is the only other chisel that will fit in my lathe. I may try a hand operation with the other chisels I want to shorten.
