A55 Smoothing Plane
Paging Bill Houghton....Docking Saw
Marv
>Hi Bill,
You inspired me to recondition my old rusty Docking saw. Does your's look like this one?
Marv
Re: Paging Bill Houghton....Docking Saw
Very similar
>It's currently in storage, and it'll be a bit before I can get it out, but that's it as I recall it, although I'm not sure mine is skewed (but I'm fairly sure it doesn't have a nib).
Re: Very similar
Marv
>They were not made with a nib, but they were all made with the skewed top edge. All were filed with "peg" teeth. Disston referred to them as "tenon" teeth. Mine is a 30" blade with 3-1/2 teeth per inch. Disston also made a 36" blade.
Marv
Stephen Shepherd
I have seen...
Stephen Shepherd
>ice saws that look similar.
Stephen
Re: I have seen...
Marv
>Ice saws are similar, but will have much larger teeth, like three times larger, also with the "peg" style teeth with a straight back, much wider blade. Disston made what they called a Pond saw that was longer with a horizontal steel handle much like the handle on a pit saw. The docking saws were quite small at the toe end, only about 2-1/2" wide. Mine has been filed down to 2-1/8" These were rough cutting with extra set in the teeth for sawing wet green soft timbers. However, they did taper grind the blade. The ice saws were made significantly different in shape and size with different style handles while the Docking saws were basically all the same.
Marv
