We value your privacy.
>My favorite chisels are some old Stanley 750's. The problem is that the handle on one of them will not stay in the socket, no matter what force is applied in use. Is there anything that I can use or do to keep the handle on that is not "permanent"?
>First and easiest is to check the length of the tenon. It is probably bottoming out in the socket and taking 1/16" off will let it drop on down, and it can bite.
The second most likely possible reason is the shoulder on top of the tenon needs to be shortened a little. Take a file and work it around, again removing a generous 1/16.
>You`ll find an article by Bob Smalser that pretty much covers all you`d need to know about fitting,care and feeding of all things chisel,especially socket chisel.
He uses epoxy to keep the chisel socket locked to the handle.Makes sense as alittle heat(not enough to discolor the socket unless you`re careless)will cause the handle and chisel to part ways if the wood is damaged and needs replaced.
I`ve used this technique only on loaner chisels but it works well there and I have no complaints.
