Best finish for a cane?
Ed Snow
>Need to make and finish a cane. Any recommendations on a finish that will be good on the hand and yet weather resistant?
Thanks
Ed Snow
Thanks
Re: Best finish for a cane?
ThomD
>Actually that can be hard. The best weather finish is spar varnish; spar varnish over epoxy (not worth it in this context). Various oils like Watco marine. CA glue French polished. French polish with a little drying oil in it. They won't hold up as well as varnish but should be fine for a cane unless you are wadding rivers with it.
The problem with varnish is that it is not hand friendly. Spar varnish though outdoorsy is actually a fraction stickier so you might do better with a harder indoors formulation or 2 pack lacquer. The trick with paddles and varnish is to varnish them with some really hard stuff, and then remove the shine from the surface where your hand will go with 320 grit. You can wax it to get rid of excess dullness. What causes blisters is the super smooth surface! Of course you have the option of having a separate handle finish. I do that on my paddles the top hand is one thing and the bottom another. At least on paddle where I don't get the top hand wet, which is not too many of them, but freestyle and Olympic might be in there. The duo finish thing reaches it's zenith with heads of different materials, which is the norm or "quality" canes.
