apple drying question
Bruce, a MN Galoot
>I have a couple saw handles that are in need of repair and I don't have a supply of apple wood to fix them. Nor do I have a sacrificial junker handle.
However, there are a bunch of orchards in the area, so I was wondering if I could get a couple chunks of tree and accelerate the drying process by cutting a few pieces oversize and throwing them in the oven (when LOML isn't around) for a couple hours at a low temp. Bear in mind, these are for repairs, not 6-7" wide, wide enough for a totally new handle.
Bruce
Re: apple drying question
Stephen Shepherd
Stephen Shepherd
>Bruce,
Just don't heat it above 185 degrees.
Stephen
No
Bill Tindall, E.TN
>If you put the green wood in the oven it will check severely. Ideally wood should dry so there is little moisture gradient from inside to outside, and rapid drying is not the way to achieve this goal.
It will not take long to air dry small pieces, probably less than 30 days for a piece the size of a saw handle. In this case I would coat the end grain.
The turners have a sick trick. The submerge their green wood in ethanol. The ethanol rapidly replaces the water and "freezes" the wood dimension. When the piece is removed from the ethanol the ethanol rapidly evaporates leaving behind dry wood. there is reason to suspect the remaining wood could have stress locked in, but that is speculation on my part. I have never done it myself.
Jack Guzman from Maine
>Bruce,I have some scrap apple laying around.Been dry for years. They're not very big pieces but should be what you need.What size piece do you need? I'll send you a piece.Let me know.---Jack
The generosity of the folks on this board
Bruce, a MN Galoot
>absolutely astounds me. I truly appreciate it. These particular saws have munged up upper horns and my dad's initials carved into them, so replacement is out of the question. Repair is what is indicated.
Thanks so much.
bruce
scott grandstaff
scott grandstaff
>Oven is no good. Disaster cracking. I bet there is a way to do it in the oven with steam of some sort. Maybe low heat and a pan of water underneath? Never tried that.
Microwave with paper bags has been done. I'm sure someone will tell about it.
Never heard the alcohol trick. Sounds expensive.
I just boil the wood myself.
Nothing to experiment with much, just drop your pieces in water and boil it for an hour per inch of thickness. Doesn't have to be a fierce boil, a happy simmer will do it.
Peel it first.
Don't even have to wait for the spouse to leave.
After, leave it out overnight and work it the next day.
The wood has to be completely green for this to work, in my experience. 1/2 dry wood I can't figure out the variables.
But alive-2-minutes-ago green always works for me.
Certain woods have natural pigment in the bark and sometimes I'll toss in chips of bark as it boils to make the wood look older.
yours Scott
Bruce, a MN Galoot
>That's a good tip, Scott. I'm going to get some of the culled trees after harvest this year. There are a bunch of orchards nearby, but they're all busy. Of course, if I had some actual patience this wouldn't be a problem. :-)
Bruce
I hate doing this
David Miller from Iowa
>I sometimes hesitate to post on here because often people don't answer your question, rather they change the question to fit their answer (my recent posts about tiger oak finish excepted, thanks Wiley and others).
I don't know the answer to your question but I will do what I despise change the question to "Does anyone have a junker apple handle?" and the answer is I probably do, send a photo of the damage, and I'll see what I can do.
David
"Shop" with care
>This used to be an apple growing area before the [unprintable] grapes moved in, and I spent a year or so clearing an orchard with a friend. At least around here, the apple trees get hollow really fast. I wound up with just a little bit of potentially useful wood (lots of firewood, understand...).
This may be a varietal issue - the Gravensteins that were the standard crop here may be particularly prone to rotting in the center.
So inspect the wood you get and grab the soundest chunks of trunk.
Also, of course, halve or quarter it immediately to get the pith out.
For the little bit I did salvage, air drying went quickly and fairly well. It's a nice, gentle wood.
Re: "Shop" with care
Bruce, a MN Galoot
>Bill,
I'll keep that in mind if'n I procure some decent apple. Of course, I know nothing of the trees that they cull or why.
Does grape vine yield anything useful, besides a good Chardonnay? Even Russian olive makes some good wood, if you keep a gas mask on while turning it.
bruce
Any red wine grapes cuttings make the best...
Scott Burr in Ben Lomond CA
>BBQ wood for beef you've ever seen. After that if you can get cuttings you can make wands and other thin crooked spindly things.
Dominic in Bucks County PA
Re: No
>Bill,
You wrote:
"The turners have a sick trick. The submerge their green wood in ethanol. The ethanol rapidly replaces the water and "freezes" the wood dimension. When the piece is removed from the ethanol the ethanol rapidly evaporates leaving behind dry wood. there is reason to suspect the remaining wood could have stress locked in, but that is speculation on my part. I have never done it myself."
"Sick"? Yeah, I'll buy that! :>)
Actually I have soaked small pieces of dogwood, apple, osage, cherry in denatired alcohol and it's worked just fine for me. I soaked em' overnight and then wrapped them in paper for a bit. After that they sat "stickered" on a shelf until it was time to use them. I was using these pieces for turned tool handles and such. But I think that the process would work for pieces meant for "flat" stuff as well.
See ya around,
Dominic
Re: I hate doing this
Tony - Memphis
>Ha! I thought I was the only one who had that impression! Sometimes, I start typing a response only to realize I'm not really helping, so I just hit the back button and read the next post.
Tony
Marv
>Hi Bruce,
As you probably already know, not all applewood will be the same color, it varies from very light to quite dark. It is only by chance that you will get new wood that will match in color with the old wood.
My point is, you don't have to use only applewood for your repairs. Any wood that you might have on hand that is close in color to the old handle wood will work just fine. Often times the results will be better.
Stains work to some degree to make the two colors match better, but it will still, in most cases, not be unnoticeable, that is if color match is a concern.
Marv
ThomD
>What you can get away with is sawing off some branches, and turning them wet, and finishing them all at once. They can seem a little clamie, and they might lightly rust a tool, but it will work and I have done it many times.
You can also try microwaving the tool handle. They used to say that dried wood from the inside out, but whatever it actually does, it can sometimes be effective. Turn first to get rid of as much excess as possible.
What does work is vacuum bagging the wood. This won't get bound water out, but it will get the extra wet stuff. At this time of the year, the trees are probably already there. But something as simple as plugging your stock into the end of your shop vac will work. you need the equivalent off 4 x 1/4" holes to provide bypass air to the motor. Holes in your hose like the ones some have with a built in slider. So if your hose doesn't have these you will need something like a section of garden hole with the holes in it, or use some tape to sabotage the fit of your hose parts.
