Krenov wall cabinet question
Wiley Horne--So. Calif.
>Hi Folks,
I'm in the final throes of putting together a small, single-door wall cabinet. It's a little over 21" high by 17" wide by shallow depth. V-shaped door, projecting outward, with glass.
I've been at this point before, and am never happy with how to do this. The problem is very simple--installing the little bars that back the glass and hold it in place. As I understand it, the typical way to install is with brads through the little bars and down into the stiles and rails. If you go that way, surely you have to predrill for the brads--otherwise you're hammering thin wire brads into hardwood and trying not to break the glass in the bargain.
But how to do the predrilling....I will have to use a small drill--a number drill, less than 1/16"--the little brads mic at 0.048" or so. Which means I need an electric drill with a big chuck on it, which is capable of closing on that tiny brad. To locate the bars for predrilling, I need to use the glass, or a spacer the same thickness as the glass. The big chuck means that I can't use the actual glass to set the location for the bars, unless I drill at about 45 degrees, so I guess I need to find or make very low spacers--little strips about 1/8" thick, the nominal thickness of the glass, to press things into place and do the drilling.
But the ripply, lightly-seeded glass is a bit irregular--it's not exactly 1/8" thick down its length. So the spacers will be an approximation.
Plus I'm not totally happy with brad heads showing, even if they're correct for the purpose.
The whole business would be a lot cleaner and simpler if there were some sort of adhesive product that could be used to hold the bars in place behind the glass, where the adhesive holds reliably, but is not permanent....meaning you can get the bars back out to replace the glass if there is an accident in the future. I'd really like to proceed very simply: Get the glass into place; then put a bead of adhesive behind the glass; then press the retaining bars into the adhesive; and be done.
Is there any such adhesive? Or alternatively, maybe I'm just dumb and am doing the brad installation in a difficult way.
All help/advice/scoldings/war stories--will be much appreciated.
Wiley
