We value your privacy.
>I've been putting off finishing a rocking chair, and that little bugger is going to be my winter project.
I want to use a tapered socket and matching tenon on the leg to fit into the seat, but I'd appreciate a recommendation on who makes a good tapered reamer for that purpose. My intention is to drill the hole with a brace/bit and then tapered that hole with a reamer/brace.
Lee Valley makes what seems to be a good one, at about 1/3 the cost of the one available from Mike Dunbar. Is Dunbar's really that much better? Are there better alternatives out there?
>I had to do a tapered blind hole and used the device Pam linked to. It got me a tapered blind hole but the aggravation of making it and learning to use it (loop through these steps a few times) made buying one for through holes seem a bargain in spite of the fact I am cheap. The issue is that there is a terrific amount of force needed to shave end grain unless dainty shavings are taken. I never figured out how to make dainty shaving with this arrangement. It would have worked better in pine than maple.
You'd have to be familiar with what the various dimensions are according to taper pin size or nominal machine taper. Taper pins are general small in diameter and are used in machine work to locate and align. Morse and Brown&Sharpe tapers are larger and generally are meant to hold objects to a spindle hole. Your drill press likely has one of these tapers into its spindle and another into its chuck. For instance, my cheapo table top drill press has a 3 inch rod with a Morse #2 male taper on one end going into the #2 Morse taper spindle hole and a Jarno #3 taper at the other end going into the drill chuck Jarno #3 hole in the chuck. These are all shallow tapers that are meant to be self-holding. They generally don't come apart without special effort or heat. When your drill chuck falls out of the drill press from side forces on a drill, or whatever, either the spindle taper or chuck taper "let go". Some chucks are threaded to prevent this, of course, with the price being less precision and greater run-out.
Here are dimensions for taper pins and standard self-locking machine tapers.
The Morse and B&S tapers I have are incredibly sharp. They cut mild steel. However, they have limited relief behind the cutting angle and a pretty high cutting angle for woodworking, such that the harder the wood the better probably. A spiral reamer might be a better choice than a straight reamer, but I don't know.
I bought Mr. Brown's little book some years ago and very much admired his shop, his approach and his Luddite sensiblities. Can't recall how he did it, but I'll check if I can remember to search the house for the book. I'd guess his approach is the world's simplest and most elegant.
I looked at the LV reamer and it's taper is around 12 degrees. The Dunbar offering looks to have a similar taper. The tapers I was talking about are of about 1/2" per foot, or 2 or 3 degrees. Two very different angles. I also see that these non-locking (I presume) angles for chair seats are meant to match tapered dowel cutters used on the chair sticks, so matching angles is critical, I'd guess.
I wouldn't like spending $60 for a tapered spoon bit, but it seems like the high class solution. Still wondering what Brown the Luddite used.
>I have made and used a couple (different sizes) following the John Alexander plans that Pam linked to. They work well enough to have used them several times in poplar seats, although as Bill points out, shaving end grain is tough. Pete Galbert (windsor chairmaker) uses this style and says he likes a shallower angle (about 6*-8* I think) as opposed to the 12* for the LV tapered reamer. Easy to adjust this angle if you make your own. The first one I made, I left the saw teeth on, as Alexander suggsts, and found that while it did not affect the tapered hole, it was hard to extract the reamer (as you need to do occasionally to clean out dust/shavings). I filed off teeth and put a bur on both sides and found that this worked better.
>I honestly don't know what that means. Looking at the various offerings on LV for tenon cutters and taper reamers, it's very confusing, too many choices. :) And for an even greater treat, searching in gardening for tenon cutter yields the Veritas� Tapered Tenon Joinery System shows up.
But back to the question, what does it mean to say a tapered mortise matches a straight round tenon that flares at the shoulder?
>The tenon cutters in the gardening section are for rustic stick furniture.
For "finer" furniture like Windsor chairs, the "tapered tenon cutter
(http://www.leevalley.com/wood/page.aspx?c=1&p=54835&) will cut tenons to match holes made by the "standard taper reamers" (http://www.leevalley.com/wood/page.aspx?c=1&p=54864&) or "pro taper reamer" (http://www.leevalley.com/wood/page.aspx?c=1&p=54865&).
>I think that I'll experiment with the homemade version, and if I can't get consistent results, then switch to the Lee Valley reamer/taper cutter combo.
Sorry for the tardy response. I'm on nights this week, and thus sometimes am not as quick as I should be. Hard to believe they trust us with hundreds of millions of dollars of equipment. :-)
Glenn Madsen, near San Francisco------WebKitFormBo
Guest
Re: John Brown`s choice------WebKitFormBoundarymGT
>That matches up with the folks in my ongoing chair classes here in NorCal. Finishing up the first year, we still don't cut tapered holes. Brace & bit, and where appropriate, a wedge from the other side...
>You are welcome Pam but I haven't been with them for, about 3 years I guess. Nowadays I am a stay-at-home dad and trying to make a decent income as a woodturner. Good thing my girls are turning out ok. LOL
>Had no idea, that's cool, bet the girls love having Dad around all the time. I thought everyone might want to see what you're doing, so I've copied a photo of your beautiful Apple bowl.
