Micro Rebate plane.
Micro Rebate plane.
Micro Rebate plane.
ThomD
>Got one at LV the other day. Looks like a bit of a toy, but it is easy to use, and I immediately found a job for it cleaning up some moldings. I had pulled out an old molding plane, and cut some pine moldings with it. It took a few passes to get the blade just the way I wanted it, and as a result I got a few edges on the moldings from pases that had placed the shoulder cut in different positions. Got right in there with the mini and cleaned them out. It seems as though it will be fairly useful. I can imagine some tenons where it will be easier to reference when cleaning up in corners. Also, when I go to the summer house I take one box of tools, and it usually doesn't have a rebate plane in it. But this thing doesn't weigh much or cost 300 bucks where loss is an issue. Could be handy.
Re: Micro Rebate plane.
Paul M.
>Mine's still on order. I have the small Lie Nielsen shoulder plane, and that is still a bit too big for cleaning up the small binding channels on the edges of guitars. This little toy looks ideal for cleaning any irregularities in these channels after the screaming laminate router has had it's way.
I thought briefly about getting 2 and turning one into a compass shoulder plane for getting into the binding channels at the waist of the guitar. This toy is so small that it wouldn't be hard to remove material to round the sole lengthwise. But this has a low bedding angle which doesn't leave much meat for removal to get a compassed shape. So I just ordered one and will see how it works once I get it.
sized right for flooring grooves
Simon St.Laurent - Dryden, NY
>Of course I get it now that most of my flooring's installed, but this could have saved me lots of time with a Dremel, and made it look nicer too!
So far, so good. I'm reasonably certain I'll find more use for it, especially as there's more flooring to do eventually...
should clarify - groove on top of tongue
>It doesn't fit in the groove that the tongue fits into, but it's perfect for trimming the surface right above the tongue that seems to be the main place to adjust after you've (ahem) screwed up a bit.
