Re: The Real Answer
ThomD
>If you want a practical lathe, but one that is foot powered, I would go the tapers and threads root. It is much more versatile, and you can pick up a quill on ebay for a few bucks, then sell it back to ebay customers if you change your mind:
http://cgi.ebay.com/Spindle-for-Southbend-Lathe_W0QQitemZ250527515479QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a549a8357
In the old days people wanted the biggest spindle MT hole possible, but a number of the super lathes these days have standardized around an MT2 taper, as in a lot of small metal lathes.
If you do recycle a spindle, check with Oneway whether they have adapters for it first.
If you want to make your own spindle, then you probably already know what to do. One route though is to buy some spindle tubing, bore the taper, and then ream it with an MT reamer from the likes of:
http://www.victornet.com/subdepartments/Morse-Taper-Reamers/2549.html
Those reamers are about the same price as plastic ones I bought to keep my lathes clean!
I would also probably go the Richard Star lathe route, as in his book, and more recently a woodworking mag had a pattern for it. Also was in the FWW book on making your own tools. But I haven't made one, so that is just a guess.
