1882 Miller Patent Plough Plane Kit *LINK*
>I have finally got it together and completed the 1882 Miller Plough Plane Kit by Paul Hamler.
There is a link to the article below.
Re: 1882 Miller Patent Plough Plane Kit
GolfSteve in Calgary
>One of my regrets is that I didn't buy the kit when it was available.
Looks good, Derek,
Cheers,
Steven
'Bout time Derrek...
Scott Burr in Ben Lomond CA
>It's almost, almost looks as good as mine. See if Jim Reed still has, or make a set of blades for it. If'in your gonna use it.
It's my go to for grooves dude.
Re: 'Bout time Derrek...
>Hey Scott, what about posting a pic of yours - I'd love to see how you treated the highlights. Also, did you add a patina or let it age naturally, and have you use a finish on the bronze to retain it?
I will likely give Jim a yell, although I have two other choices: I can simply make my own blades (I have the steel) or I might add a groove to the back of the blades for my Veritas Small Plow plane (as the blades are the same length and thickness - but it would be nice to have a dedicated set for this plane).
I figured everyone was sick of looking at it...
>Here you go Derrek. A little patina added to her, wax as a finish.
About finish
>Thanks Scott. That is beautifully done. How can one be tired of looking at it?
Did you have add a patina via chemicals?
What I did was to buff up the raised ornamentation to a bright finish and leave the background matt. I like the contrast created. It would be good to keep. At the same time I want a little aging to the brass.
What I had planned to do was to simply leave the metal as is for a few months. There with be some natural oxidation. At that stage I can either wax the plane (my preference at this stage), or I can go for a permanent finish in the form of a lacquer spray on non-working parts.
Any ideas/comments?
Kit or not, it's a beautiful tool....can I have it
Marv
>Scott,
If I understand correctly, when you got the kit, it needed lots of handwork to remove casting flash, etc. It only looks as it does because of hours of tedious filing and sanding and fitting and finishing?
Great job!
Marv
Re: Kit or not, it's a beautiful tool....can I hav *LINK*
MikeW
>Hi Marv,
Mine took 3 hours or so. The linky is to the original WC thread I did in March of 2007. I have since moved to a new server host but I could place the pictures back up if wanted.
They are not fussy to do at all. Following my original posts, I bought the set of original thickness cutters from St. James Bay. That took a bit of judicous milling to make them fit. They are substantially thicker than the as-supplied 1/4" cutter.
Take care, Mike
Linky do wopper
Marv
>Thanks Mike,
I think your post on the other end of that link is too old, there was no pic. Scott's pic in that thread didn't show up either.
Marv
Wiley Horne--So. Calif.
>Hi Derek and all,
You did a beautiful job. And perhaps it should be said that Paul Hamler's original casting came in great shape--the guy is amazing. It took me about 3 hours (of actual heads-down work) to get the casting seams off mine, using mainly needle files and sandpaper. A Dremel would have significantly helped--would have been a great excuse to buy one also.
I would like to second Scott's suggestion of checking with Jim Reed in regard to a blade set. First of all, he did a great job for a reasonable price. He might not have earned enough for the work that was required. But beyond that, I would suggest talking with Jim even if you plan to do the work yourself. If I am recalling right, Jim considered it a very tough job to get those V grooves milled into place. So by all means, check with him.
Again, a beautiful job.
Wiley
A fine idea you have Derek..
>I went with a mild chemical patina. I followed Paul's directions completely. I spoke to him several times as I put mine together. He's a great guy to talk to. Then I polished the surfaces as you have. Them a few coats of wax.
I think your plan will work out well. With the natural aging process. A few others have done theirs like your planning to do.
I never have a problem looking at it, or using it.
I have built a box for it and the blades I received from Jim Reed.
Here's a better pic...
It took some time for me...
>There was a bit of a learning curve. Yes, a bit of grinding to remove the runners, filing and sanding the flash off. Then the polishing and patina process was all new to me. I just took my time, I wasn't about to screw this plane up. It as also the first time I have ever peined anything together. It was a slow and scary process for me.
MikeW
>Well, like I mentioned, the web site had been moved and I was really just pointing to an answer as to how long it took. Which is about how long Derek posted on his web site at his link.
The black background makes the color of the plane richer than it really is. Like Derek, I opted to leave the discoloration in the recesses rather than use the patina stuff from Paul.
Take care, Mike
Sadly
Dean Lapinel
>Sadly it's time to give mine up. Do you think these will do OK on e-bay (finished and with jims blades)?
Re: Sadly
>Dean,
I have seen them offered every now and then. For example, by 2Lshark. Going by rough memory, they tend to bring approx. $300, plus or minus. However, here is one which just went for $587:
http://cgi.ebay.com/HAMLERS-MILLERS-PATENT-STANLEY-COMBINATION-PLOW-PLANE_W0QQitemZ220500556921QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3356db7c79#ht_2098wt_1167
What is hard to make out from the listings is whether the price differs between Hamler planes assembled (and marked?) by Paul Hamler himself, versus ones assembled by one of us.
In terms of strategy, I wonder if you might be better to offer the Hamler plane with original iron--just as received in the kit--and list the Jim Reed irons separately.
Wiley
Re: Sadly
Dean Lapinel
>That's a good idea and thanks for the information-
Dean
Marv
>Thanks Mike for the pic. Beautiful work! Looks like a fun project. Is there some kind of fraternity one must join to own one of those things? Was there a limited number of them made?
Marv
MikeW
>Hi Marv,
If I recall, this batch was left over from Paul's first run of castings (and sales). The link below goes to Ellis' posting on Paul's behalf.
There were 80 available for sale. There is an email address for Paul in the ad below one of the pictures. I don't know if it is still valid or not.
Take care, Mike
Original Ad Posting
