New shop evolution + making window moldings...
John Aniano - in central NJ...
>Hello All,
(Warning - substantial amounts of electrons were employed to remove stock, please turn away from your viewing screen when the word "router" is mentioned...)
We had a new pole barn constructed back in January 2007. The pole barn replaced a dilapidated wood frame chicken coop that straddled the property line. When the property next door became a county park, they wanted the building off their side, and paid (thankfully!) to have the whole thing removed.
The design of the second floor of the barn was to be passive solar - "a room within a room" as my neighbor described it. He built his own passive solar home back in the late 1970's, and he was the inspiration for this shop design. The new pole barn faces nearly due south, has a large southern-facing overhanging roof line that shades the six 2nd-floor south-facing windows in the summer, but lets Winter sun through to heat the shop. The total R-value is roughly 30 for the shop space. We had an architect do the design so it could be approved by the town's building inspector. Before the room upstairs was sheet rocked, I ran BX electrical lines for outlets, lights and ceiling fans as well as outlets and lights on the first floor garage portion.
Three large windows were added on the first floor after the red siding was installed - it was too dark inside the first floor. This picture was taken before the windows were added.
A friend helped me install the white oak flooring - we bought a pneumatic floor stapler on ebay and it worked great. I paid a professional to sand and finish the floor. Since the flooring install took nearly 1 month of working for an hour or so in the evenings, renting a stapler wasn't a good idea. I don't do anything all that fast...
I made and installed the baseboard molding myself. The window moldings (there are 10 windows) are a copy of the circa 1840's moldings in my home's center hallway. I did use an electric router for much of the work on the main sections of the moldings, but hand planed all the surfaces that would be seen. Used a Stanley #92 for the bottoms of the narrow grooves and a wooden side rabbet plane for the edges of the grooves. All had 5/16" beads cut on one edge using an English beading plane. I used very little sandpaper before priming and painting - no real need for sanding after being hand planed and rubbed with shavings.
The corner blocks and sills were made by my contractor who did the majority of the installation - he put in the sills, blocks, and extension jambs and primary moldings. He joked he could do it in a day, and since this would take me eons of time by comparison, I said "yes - you have the job". He does wonderful work, even with my insistance on not having any "reveal". Actually, the day of the installation he said to me "how much reveal do you want"? and I said "What is reveal?". I wanted it to look like the 1840 portion of our home, so we negotiated to have no reveal - as he muttered "give the customer what he wants even if it is wrong"! It looks great!
After he had left, there was still some extra moldings to be made, specifically the stepped bottom pieces and two center primary moldings for the double windows. The extension jambs needed to be cut and fitted before these two molding could be made to fit exactly. I again use an electric router for roughing out, but planed all the surfaces and cut the edge beads by hand as before.
I did make most of the stepped bottom trim by hand using a badger plane. At 0.008" shavings, it took ~100+ passes using the badger plane to make each piece. A huge amount of shavings resulted - these are great fireplace starting kindling. It was fun but a lot of work. An electric router would have been faster, but I've heard this kind of exercise "builds character".
Painted all the exposed surfaces with tinted primer and two coats of paint and these final pieces were ready to install! Although I own a finish nailer, I don't own an air compressor, so after borrowing my neighbor's compressor, I spent a day doing the last of the trim work. I still have a ton of tiny nail holes to fill, sand and paint, but the job is 95% done.
The last two photos show the near finished results. In the first, is the large plank for the Roubo-style bench top plus a shaving horse - a gift from a friend. The other shot shows my new bow making bench in place with work in progress. I got the Stanley tool cabinet at the CRAFTS auction last April, and Lee Valley steel shelf brackets are holding it up against the wall.
It is slowly taking shape!
John
