A55 Smoothing Plane
Interesting old handsaw vise on Ebay *LINK*
Marv
>Here's an old vise that might inspire some ideas... Simple design using the flexibility of the wood inplace of a hinge.
Marv
Neat old saw vise
Re: Interesting old handsaw vise on Ebay *LINK*
Opps, wrong URL....sorry *LINK*
Marv
>Hope this one works....Hrumph!
Marv
Neat old saw vise
But it has no providence
>How can you buy an improvident saw vise?
No providence, but
Wiley Horne--So. Calif.
>it will still work, for all intensive purposes.
Wiley
at least it's not impudent
Bruce, a MN Galoot
Re: But it has no providence
Marv
>Bill,
I see what you mean, not having any "providence" is a major drawback for sure. lol Maybe the seller is in Rhode Island.
Aside from that little distraction, some good ideas to be had.
I'm not the seller, by the way, I ran across it this morning while scrolling the handsaw auctions.
If I were to make a vise similar to this one, I would use a thin strip of sheetmetal at the bottom for the hinge. I've used this method on other fixtures where I needed a sturdy small amount of movement at the top end with no sideways movement.
Marv
Trumped by cool factor
Bob Hackett
btw, Marv, not to ask a serious question here, but
Bruce, a MN Galoot
>is a 3D one of the okay ones? It's currently holding one of my garage sale finds.
Bruce
Pam Niedermayer, Austin, TX
>I was thinking that, depending on how the bolt was attached on the back, perhaps the jaws could be forced apart a bit by the bolt.
Pam
Re: btw, Marv, not to ask a serious question here,
Marv
>Bruce,
As for vises we see on eBay, the Disston 3D, IMO, is my choice of saw vise. It's big and beefy and has wider jaws than most. It does have a couple drawbacks though. The bench clamp is inadaquate if you are filing, say, a 5PPI rip saw. When I was using my 3D before I got my big Acme vise, I did some bracing up behind the jaws so it couldn't move and vibrate. The other inherent negative about the vise is, the cam will wear an indentation into the casting it bears on. When the indentation gets worn deep enough, the jaws will not stay clamped. So depending on how much the vise has been used and depending on if the user of the vise lubricated the cam will determine the amount of wear on the older ones. They are all older ones..filings find their way down into the cam area and acts as grinding compound. I have bought several 3D,s on eBay that were barely used. :))
Marv
Marv
>Pam,
I think the seller indicates there's a spring that forces the jaws open. If there isn't a spring between the front and back, there should be. It could be a leaf spring or a compression spring.
Marv
Unlucky!
paul womack
Re: Unlucky!??? What U mean?
Marv
