Folding rules, backwards
link van cleave
>I like folding rules however I find them to be made backward. When the rule is folded you can see 1" 2" 3" etc. When you use just one or two of the leaves the rest of the leaves are in the way under the first leaves making it impossible to lay it flat and use it on the flat in a natural way. You have to use it on edge. If you lay it flat you are looking at the back numbers . In my case 60", 59" etc. Two questions, why and does anyone know of a rule that is designed so that you can use it flat ?
Thanks,
Link
Re: Folding rules, backwards
link van cleave
>I looked around and found some they call flat reading rules. Seems to be what I want and address the deficiencies I noted.
L.
Folding rules
Bob Hackett
>The surveyors in the shipyard I used to work at would save the pieces of their broken rules for the shipfitters.Many found them handier than conventional rules.
MB
John Pappas
>I'm just curious..why do you feel it is necessary to have the ruler down flat. I use my folding ruler on edge, and I think it's easier to line up to the markings that way. Also, doesn't the end with the hook suggest that this type of ruler is used on its edge?
They don`t all have a hook.
Bob Hackett
link van cleave
>"why do you feel it is necessary to have the ruler down flat."
Even though I suspect your question is rhetorical I will answer it.
It is not "necessary". However it is what I want. It suits the way I want to work. I use my tape measure flat and on edge but never a 1 1/8" in the air.
I have found some configured the way I want . They are called inside rules as opposed to outside rules.
I like to be able to use them flat or on edge. With the outside rule you are restricted to using on edge unless you can hang the stacked blades off the edge of something. With a inside rule you can do both, flat or on edge. I like to set my table saw fence by bringing a tooth down on the ruler. There are other times I like to have it flat and sometimes on edge is good for the reasons you mentioned. With a thick ruler you can get parallax and you are right about on edge addressing that. However sometimes when on edge you have to crane over to see the lines or kneel. It can be awkward.
So for me it would be way more useful. Also this type of folding rule usually doesn't have a hook. They sometimes have a extension for inside measurements.
Link
Good response. thanks
John Pappas
Bruce, a MN Galoot
>That's the kind that my dad and I carried all the time in our back pockets. We also got them left-handed, so that we could hold them with our left hand and mark with our right without having to read the ruler upside down.
Bruce
Metal folding rules
>In my garage sale travels, I've picked up a few all-metal folding rules - same zig-zag construction as the wood ones, but without the extension slide. Mostly, they seem to have been made in Germany.
I found, in testing them against my Starrett rules, that most of them weren't accurate, though; but for the price (about 50 cents to one dollar each), the rejects were worth it for the one six-foot rule that tests out accurate (the others went on to rummage sales for those with less fussy needs than mine). I don't use it often, but, when I need it, it's nice to have a rule that long that I don't need to figure out how to store. I tend to unfold it completely, leaving the excess to flop around on the far end of the bench.
Brad Chenoweth
>Link,
What you want is a Lufkin 066F. Reads on the inside, so you can lay it down flat.. Also, reads right-to-left on one side and left-to-right on the other side. This is the rule my late carpenter father carried daily for over 40 years. I still have a couple in the shop. No hook, though.
Brad Chenoweth, in Elyria,Ohio
Lay flat + extension?
Wiley Horne--So. Calif.
>This is likely wrong. But. As best I can figure out, you can either buy a 'lay flat' rule, like the Lufkin 066F or the Starrett S060F. Or you can buy an extension model, like the Lufkin 46X or the Starrett S060.
But you can't buy a carpenter's folding rule that is both 'lay flat' and has an extension.
Is that right or wrong?
If wrong, which one has both features?
Thank you,
Wiley
Re: Lay flat + extension?
link van cleave
>Thanks Brad,
Hi Bill in Sebastopol.
Wiley, I have searched and found what you have found, or should I say not found.
Inside read plus extension. Doesn't seem to be available.
It's funny most work pants still have pockets for folding rules while the rules and the use of them have all but disappeared. Same with watch pockets in jeans.
Thanks everyone. I will get the Lufkin and check for accuracy.
Link
Re: Lay flat + extension? *LINK*
Marv
>Is this what you are looking for?
They all lay flat..I don't see how else they could lay.
Marv
Folding ruler with extension
link van cleave
>Marv,
This issue isn't whether the ruler can be laid flat, it is when it is laid flat to the work if you can read from 1" on up or if you are looking at the end numbers. The ruler you linked to can not be laid flat to the work (with out completely unfolding it ) and have the numbers readable unless you want to work backwards. This is better explained in the previous posts. Look at a "inside" ruler and compare.
L.
Marv
>Link,
Ok, now I understand what the issue is....just got done playing with mine. It depends on if the stack is up or down. Just seems silly not to have all folding rulers read when flat down and the stack on top. However with the extension included, it would be more difficult to design it so it could slip into the folding/pivot point and still be able to extend 6 inches. It's all about the extension.
Thanks
Marv
Still using folding rules
>Hey, Link. Some day we need to meet face to face - what are we, ten miles apart?
I've talked with a few young carpenters, including my son, who still use them - so they haven't died out altogether.
Marv
>Ace,
It looks just like my Lufkin that reads on the bottom side.
Marv
Ace Karner
>Whatever, I just know mine reads left to right whether it's an outside read or an inside read. I'll take pics tomorrow if ya want.
The 1 is on both sides on one end and the 71 is on both sides on the other end.
>Thanks much Ace,
That is a very helpful link to the Starrett SX40f. I'm getting one while there are still some available. Lee Valley has given up trying to source them.
http://www.leevalley.com/wood/page.aspx?c=2&p=32560&cat=1,43513
Don't have anything that gives a good reading inside a case.
Wiley
Marv
>Wiley,
Often times I've had to get an accurate inside measurement. All I do is use two sticks that are shorter than the measurement I need. I slide the two sticks so they touch each side and clamp them together in the middle. Then I measure the length. I've even done it from floor to ceiling.
Marv
>Hi Marv,
I do that too. And similarly for checking diagonals, too, where you need to get all the way into corners with a point. I don't think this carpenter's folding rule is a necessity--I doubt they had them in 1670--but I do see it is useful.
What this rule will do for me beyond two sticks, is add some quantification. When checking internal case measurements, I want to know if this measurement is a 64th different from that one, or more, or less, and how much. Do that with a metal tape, and you're trying to read small differences off the tape where it disappears into the plastic reel. With the metal extension, you can read small differences in a cleaner way. And I don't care if the thing is graduated in 16ths--it's easy to interpolate provided you can cleanly see the scale.
Anyway, I'm glad Link brought this up, and hope he find what he's looking for also. I do think Ace pointed us the right way.
Wiley
