Cleaning heavy grime--what to do?
Wiley Horne--So. Calif.
>Well, not exactly grime. Not really oily. But it's black--and beyond patina. This past summer I bought a plough plane off Ebay. $72. Screw-arm plough. It looked so dark in the photos, that I thought it was possible rosewood. Looked to be in sound shape underneath whatever was making it so dark. Winsted Plane Co. Founded in 1837 and listed in directory as making joiners tools from 1851 to 56. The A mark.
Anyway, it gets delivered. It ain't rosewood; just black with whatever a tool made 150 years ago collects. I set it aside, and didn't want to mess with it.
Tonight I got started. Steel wool (00) + Briwax. Turns out this is an all-boxwood plane underneath the black. Tight-grained enough that you can get the dirt off it. But the 00 wool and Briwax isn't quite strong enough. What I'm looking for is something that will get deep dirt out, so that the boxwood comes up clear, but short of scrubbing with anything so abrasive as to make bright scratches on the wood. Plane isn't collectible, but I still don't want scratches down into raw wood.
What do you folks do for heavy cleaning of a tight-grained wood? All suggestions will be much appreciated.
Wiley
Re: Cleaning heavy grime--what to do?
Pam Niedermayer, Austin, TX
>Boxwood planes fetch big prices even if not collectible. Worst case you could split it up and make a bunch of finger/violin planes, use the arms for wedges.
For the grime, why not try scraping it off?
Pam
Simple Green or Purple Cleaner
Alan DuBoff
>Wiley,
Try some Simple Green or Purple Cleaner, both work well to remove grease. I use a dish washing brush with it, the type with bristles.
If is it grease/grime, that will get it off. If it is old stain, you might need some type of stripper.
I would try the Simple Green first as it is environmentally safe, I like that about it. I've been using the new lemon scented Simple Green, I like it.
Cheers,
Alan
black stuff
paul womack
>I have no idea what the stuff is, but alcohol dissolves it nicely.
The issue then becomes removing the "liquid black paint" you've just made.
I use 0000 wire wool and alcohol in one hand, and a large supply of soft rag in the other (or at least kept close by)
This does leave the tool looking a bit "clean" though.
BugBear
Re: black stuff *LINK*
Bob Demers
>That black stuff is probably tallow. It was uses a lot on wooden planes as a sort of wood conditioner/preserver, preventing the plane wood to dry out. It is basically mutton grease, and it acquire a hard, black colored surface with ages.
See its composition, it should help remove it
Tallow
Re: Cleaning heavy grime--what to do? *LINK*
Paul Dzioba
>Hi Wiley,
If you look in the WC articles, in the section on finishing, Sam Simpson's article "Cleaning Antique Furniture" describes the British formula. This has worked well for me on planes and other old things.
Regards,
Paul Dzioba
Simple Green
Bob Hackett
>I`ve had great luck with undiluted Simple Green and use it as a first step on most cleaning.It will leave any "patina" in place and yet still get the surface grime off.
If the plane were relatively clean to start I might just use Murphy`s oil soap as I tend to follow the smallest stick approach.
MB
I'll be the first to say it...
John in NM
>Nice find Wiley!
you need a solvent
Bill Tindall, E.TN
>You need a slow evaporating solvent and because wood lies beneath I don't recommend one that contains any water. Things to try according to convenience used in conjunction with some fine steel wood- paint stripper, mineral spirits(AKA charcoal lighter, oil lamp fuel, paint thinner). Linseed oil or any vegy oil might even work. (There may be some CA regulation requiring a "green" renewable solvent for this task) The paint stripper is best if the black stuff has penetrated.
I have used linseed oil and 4/0 wool to good effect in cleaning antiques of black surface combinations of body oils and dirt.
>Wiley,
After you scrape off the surface accumulation you can try cornmeal or cornstarch to absorb the oil out of the wood. Museums use the stuff to clean textiles, works great on oil stains on wood.
Stephen
Marv
>Wiley,
Antique Improver and a mild solvent made by this company will do the job and will restore the wood at the same time.
I've even used it on metal parts such as old wrenches, etc. Does a great job. It doesn't remove rust, but does a good job with dirt, grease and grime.
Marv
http://www.kramerize.com/
Limited experience from automotive grease
>Hands down, the best solvent I've ever found for soft grease, such as found all over the transmissions and oil pans of clapped-out cars, is true turpentine (pine turpentine). A bit pricey, but impressive. If your hardware store doesn't carry it, an art supply store will probably have it. Either way, take a deep yoga breath (in quick, out slowly - reduces blood pressure) before removing your wallet from your pocket. But you wouldn't need much.
>Thanks to all!
The Briwax I"m using right consists of beeswax and carnauba in a toluene base. Toluene is the solvent. It cuts pretty well, but is not 100% without a lot more elbow grease on my part.
So. Going to the grocery store this afternoon. Will stop by the hardware and pick up turpentine, then get Brasso and Simple Green concentrate from the grocery. And corn starch to see what that does. Will try the British formula of Sam Simpson's (where did he go? he was great!) that Paul Dzioba pointed to in the articles; and also Simple Green concentrate on a different place and see what gives. Pam, this plane is perfectly sound and will make a fine user.
Will report back what happens. It's a remarkable thing to me that these old woodies were so well made, and the materials so good, that hundreds of years can go by, and you pick them up--and they work. Only need cleaning.
Wiley
P. S.
>Paul's alcohol and Bill Houghton's turpentine seem to be subsets of the British Museum formula, and Bill Tindall's suggestion of a solvent seems to be what I'm doing now with the toluene in Briwax (if I understand what is being said, which may not be so).
Thanks again,
Wiley
>For your information, this is my old business manager and he ripped off my Moses T's Reviver with a couple of changes. He basically copied my recipes and markets the stuff.
Stephen
Marv
>Did the changes he made improve the stuff? It works pretty well, but I find that it needs to be reapplied many times before actually making a noticeable difference with old varnish for example. Then after maybe a year, you have to use it again if the old finish isn't coated with a present day finish of some kind.
It's main purpose, as I understand it, is to "improve" an old finish. I like the stuff, but his prices have tripled since I last bought some from him. $20 plus $7.50 for shipping for 8.oz is a bit outside my wallet.
Because his is different than yours, could you also market your version under your own name?
Marv
Jack Guzman from Maine
Sam Simpson
>Wiley,unfortunately,Sam died a tear or so ago(I lose track of time).
I use that formula to clean old clock cases.It works by softening the finish so the imbedded grime can be wiped off.Even if it isn't right for your particular needs,it's worth having a little around. It's real handy stuff.---Jack
Re: Sam Simpson--Rest In Peace
>I'm glad you brought his formula to everyone's attention. It will be a reminder of how helpful Sam was, and full of knowledge.
Wiley
