Stanley No. 39 parts
>How easy would a lever cap and an iron be to reproduce, if, say, I had a line on one missing these parts?
Re: Stanley No. 39 parts *LINK*
Bob Demers
>Bill
That could be difficult, if not very laborious, read expensive.
These dado's planes have a skew iron and a somewhat overly shaped lever cap. Its bottom width, being determined by the actual width of your particular size dado plane.
See link for sample pictures
As with most antique tools, the one with missing parts are never bargains, as the elusive replacements parts are often hard to find and when found, expensive. Always cheaper in the end to buy complete specimen.
Best to consider that plane as 'donor' plane, broken down and sold for parts
PS the depth stop is often missing or broken
Catharine Kennedy
>try here:
http://www.antique-used-tools.com/stanley_parts.htm
Wiley Horne--So. Calif.
>Bill,
If you go to ebay and search 'stanley 39', you will find one example each of an iron (I think 3/4") and a lever (I think 1"). The lever is quite involved, and the iron (as Bob D. says) is not elementary.
Dept. of Free Advice: If'n you really want a dado plane, get a woodie--cheaper than a 39 and they work great. I've bought several, and have found that they're generally in good shape and usable with very little fettling. I think the reason they tend not to be 'projects' is that these were never a handyman item--anyone owning one of these things had to know enough about woodworking, to know he needed one. Occasionally I have seen one of the nicker tangs shorter than the other--stuff like that that you can fix with a file. But generally, if it looks like sound wood and original parts and had reasonable care, it'll be usable with sharpening.
Wiley
Woodie Update
>Bill,
I think I see the problem....Just checked ebay, and woodie dados are really thin on the ground now. Used to be, you could go to ebay and find half a dozen excellent British and American examples in the right sizes for $40-45.
If any interest, I may be able to help (offline).
Wiley
jimreed@tallahassee
>I have made quite a few blades using a standard 8" grinder and a specially adapted Wolverine jig. The jig keeps the grinder from eating the blade when you grind that thin stem. The blades are tricky but not impossible. It just takes lots of fittings. Lever cap might be harder.
Bob Entwisle in NJ
>You could try here for old parts http://www.brasscityrecords.com/toolworks/new%20tools.html
Joe Rogers, Northern Virginia
>Gotta say that you were on your game when you ground up that 1/4" #39 blade for me. Wish you had time to continue makeing the replacments!
JR
