Table Plans
Jerry Draper
>Does anyone know where i can find plans for a dining table that extends by pulling out either one or both ends?
Table Plans
Jerry Draper
Re: Table Plans *LINK*
Pam Niedermayer, Austin, TX
>Rockler carries table extension slides, see the link below. If you click on "More Info," you can get a much more detailed pdf of how they're used.
Table Extension by Pulling One End
Steve Elliott
>A shop I worked at built an extension table using commercially available slides that would allow both ends of the table to be extended by pulling on just one side. I don't know the manufacturer, but they're out there somewhere. It wasn't my project but when the table was done I tried it out and thought the action of the slides seemed a little noisy and barely solid enough.
At the same shop I built a series of tables that used bicycle chains and sprockets to create the same action. The movement was quieter and more solid but the design was much more complicated and mechanical than I like. My idea of good furniture design is to go for something that is simple and reliable, using methods that can be easily understood and repaired by future craftsmen.
If you're planning a pedestal table that extends you'll probably need some kind of a subtop that holds the extension slides. If the ends can be pulled out independently you'll need to make sure the table won't tip over if only one end is pulled out. There will be some limits on how far the table extends and how large the base needs to be, but I'm sure some good designs can be worked out.
Thank you.
Jerry Draper
