OT - hand tools to the rescue again!
>As part of the roof rebuild, which is part of the bathroom remodel, I'm insulating the ceiling of what we call the "low roof" part of the house. This is REALLY hard to reach, so doing it while there's no sheathing should be way easier.
since I have to crawl in that area, I'm putting down 3" sheet foam insulation (polyiso, with aluminum foil on each face), so I can crawl on top of it when I need to (ceilings are beadboard, which I already know can hold my weight). My son, who's worked with it before, said "use a skilsaw." Well...the first cut reminded me of cutting MDF with a power tool, except stinkier - clouds of dust. I had to make a little slotted cut at one end, and my circular saw won't cut 3", so I got out the handsaw to finish the cut. A handsaw goes through that stuff like it's not there. I also discovered that, for simple cuts, a razor knife cut through the foil on one side weakens it enough to snap, like sheetrock. No more electrons for me - a handsaw and razor knife can do it all, with almost no dust, at pretty much the same speed or even faster.
HA! The hand tool guy wins again!
