A tale of two miter planes
Craig D
>Not really, mostly a show-n-tell.
Two miter planes, one bevel down and one bevel up. Both have a 35� cutting angle. Weight difference between the planes is a bit over half a pound (woodie is heavier at 1.8#). Blade widths are 1 3/4� and 1 1/2�. I don�t know how to compare them since I use them for different things, the metal one mostly as a low angle block plane and the woodie as a shooting plane or with-the-grain smoother/jointer. And I don�t need to compare them, after all, you can�t have too many planes, right?
Here is a somewhat staged image of shooting a 1 1/8" walnut board. Staged in that it took a huge effort to shove the plane through the cut but no chatter and long end grain shavings! Me thinks a little more tuning is in order.
