Ruler backing . . .
Ruler backing . . .
Ruler backing . . .
steve mackay
>On my handy-dandy 15", thiner, steel rule, the cork backing has about had it. On this ruler I like the traction of the backing. Question . . . anyone ever tried leather on them ? Wondering if it might last longer than cork but also if it would do evil things I haven't thought of yet.
Re: Ruler backing . . .
Re: Ruler backing . . . *LINK*
Wiley Horne--So. Calif.
>Hi Steve,
You can get cork material in sheets. But then the gluing will be a hassle.
I think I would try 15 micron or 5 micron PSA paper (see link). Cause the adhesive is already on it, it's easy to trim flush after applying (with a marking knife), and the grit is so fine that it isn't 'gritty' feeling and doesn't shed--just has a little tack to it. 15 micron is about like a 1000g water stone; 5 micron is about like a 3000g stone, as far as tack goes.
2 cents.
Wiley
PSA backed fine abrasive sheets
Jim DeLaney, Austintown, Ohio
>FastCap makes a great double-faced tape that's only a couple thousandths thick. It would work nicely for putting the sheet cork onto the ruler.
The tape is really tough stuff - intended for putting veneer edging on plywood. Leave it on overnight, and it's close to forever...
Regards,
Jim D.
