Doh! Murphy strikes again
Edward in Vancouver
>Murphy's law dictates that the odds of a buttered piece of bread landing buttered side down, is directly proportional to the cost of the floor covering.....
Last week I got a set of skewed chisels from LV. Tonight I honed them and tried out some dovetails. Not such a bad job either, and after I congratulated myself, I watched helplessly as one of them, the right I think, rolled off the bench and onto the cement floor.
Before I started to cuss, and before I even thought about breaking out the waterstones, I knew what I should have done before I even started. I grabbed the left chisel, popped off the metal hoop, and with a block plane, shaved two flats on the bulky, albeit round handle. Then I did the same on the right.
Shoulda done that before I even honed them.....
Re: Doh! Murphy strikes again
Wiley Horne--So. Calif.
>Inanimate objects are out to get us......my favorite corollary to the Second Law of Thermodynamics.
Good idea about the chisels. And congratulations on the dovetails.
Wiley
Pam Niedermayer, Austin, TX
>Sorry, but Murphy has nothing to do with buttered bread, which lands butter down because the buttered side is heavier. Gravity's your culprit.
Pam
Seems As If Murphy Is On A Roll
So Is the Butter
Bruce, a MN Galoot
>My favorite Berg chisels also have round handles, and like all other tools, they are mischievous and like to cause me grief. The owner of my local gym remodeled the place and gave me a big piece of rubber floor mat. It sits right under my bench. Me 1, tools 0. It makes me wonder what those little buggers will try to think up to get back at me.
The obvious solution...
Marv
>Butter both sides of the bread.
Marv
which, of course, raises the old question
>If you strap a piece of buttered bread to a cat's back, will the cat land right side up?
Second best pun since sliced bread
Re: which, of course, raises the old question
Marv
>Well, from experience, if you can strap anything to a cat's back, I want to be there to see it....LOL
I'm trying to figure out how to train my cat to shred compost.
Marv
Paul M.
>Just don't try to stop them on the way down with your foot! It's a natural reaction to do that. It's also a really really stupid thing to do. Don't ask me how I know that.
>I know how you know that because it happened to me as an apprentice back in the early 1970's. A chisel rolled off the bench and I caught it, it was the last thing I ever caught. I don't have a catch reflex after so many years of not catching.
All of my chisels but one 2 inch wide slick, and it can't roll, have tapered octagonal handles. None of them have ever rolled off the bench.
I for one have no idea why manufacturers put round handles on chisels?
Stephen
Some scientists have way too much free time
Tony Z.
>If it makes you feel better, I did the exact same thing, with the exact chisels. Fortunately, the skews are slightly less hard than bench chisels and it wasn't too bad to fix.
Nope, It's all depends on the ratio...
Scott Burr in Ben Lomond CA
>Gravity takes hold ABOVE counter height. The ratio begins at counter height or below. From here on down anything goes and the 5 second rule starts to go into effect, especially when cookies are involved.
Forget training, seed the pile with catnip.
No,no
>For those of us who put a bench against the wall, leveling is not the answer: tilting it slightly back toward the wall is.
No five second rule here
Marv
>No five second rule here....Hell, I'll eat it the next day.
Gravity is in effect at the counter level before the toast is dropped because the counter is pushing upward.
Marv
Re: Forget training, seed the pile with catnip.
Marv
>Good idea....I like how you think outside the cat box. *grin*
Marv
Everything rolls toward the center
Victor Parisian
>if your bench is dished badly.
Victor
Adding insult to injury........
Bill Tindall, E.TN
>I had a screw driver and a skew chisel in my hand and was going to put the screw driver in it's looped holder and then move on to putting the chisel in it's place. While dropping the screw driver in its loop I dropped the skew. It sliced through the web between my thumb and 1st finger and then hit point first on the concrete floor. It was the worst injury I ever got woodworking and with a hand tool no less!
