How to buy planes at auction (long)
Mark in Texas
>Thanks for the feedback. I've added the following sections to my original post:
13. Incorrect or incomplete auction descriptions
These are a potential source of good deals. The item will still be spotted by the tool junkies, but at least the pool of bidders will be smaller. Also, see #5 above.
Here�s a good quote from the Woodcentral folks: "I don't know much about this plane" should be translated as, "I know something about this plane, and this is my way of getting out of having to tell it to you."
14. The Picture Paradox
Paradox part 1. As the number of high quality pictures increases, your confidence in buying the plane increases in direct proportion. Normally, the price goes up also, because everyone else also has this increased confidence. That said, nothing beats a set of really good pictures for knowing whether you are actually getting the plane you think you are. Conversely, if there are no or few pictures, the smart advice is to simply pass on that plane. Sometimes, though, you can ask a seller to post more pictures.
Paradox part 2. For gamblers only. Fuzzy or poor quality pictures will decrease the number of bidders. On occasion, I have gotten a decent deal by bidding on an auction with poor quality pictures. See #1 above.
For the visually impaired (age 50+). I sometimes copy the small, hard-to-see picture into MS Photo Editor and enlarge it.
15. Rust
Planes, and most tools, are made of iron. Therefore, rust is inevitable. I feel obliged to issue a liability disclaimer about what follows; when it comes to rust, see #1 above.
Ok. Light surface rust. This is the type that can be removed by light abrasion such as fine steel wool or a Scotch brite pad.
Not ok. Rusted so bad that it has caused pitting. This is especially bad because it can be covered up by dirt or by the above mentioned light surface rust. Hopefully, the seller will issue a statement that no pitting is present.
