Re: Up against the wall, woodworker! *LINK*
Wiley Horne--So. Calif.
>Hi Roy,
I'm in a small space, up against the wall, and in a corner, too. Attached is a link from a few years ago (and several saws ago) on the one day in history when the area was swept up and things put away.
What's good about this setup is that there are two walls immediately to hand where tools can be kept in quick reach. What's bad is everything else--inadequate lighting (I like Derek's new brainstorm a lot!!), can't clamp across the bench, can't practically flatten the whole bench unless you're heavy into scraping, and some other stuff I forget right now.
But that's life. So what can you do? First, you have to deal with the 'clamping across bench problem'. I did this by arranging to clamp against a pretty deep apron, which wraps around the two open sides--it also serves as rear jaw for vises.
Then there's the problem of storage in a small space. I put drawers under the bench to deal with that. But you have to watch out that you don't eliminate your ability to clamp at the edge of the bench, which is of course ALWAYS happening. So the apron projects far enough beyond the drawers (if you use them) that you can use it for clamping. Mine projects 2-3/4" beyond the drawers, so I can get a clamp under it for holding stuff down to mortise, for example.
But then there's the problem that the drawers are the wrong depth. Like mine under the bench are all 6-1/2" to 7-1/4" deep. Turns out that what I mainly need are shallow drawers, and lots of them. So off to the right you can see a sharpening station with a dozen flat drawers in it, graduated from 1-3/4" to 3-1/2" usable interior depth. Don't forget flat drawers, and there can't be too many. If I had it all to do over, I would put nothing but shallow drawers under the bench, and find another place to store stuff like planes--because they don't fit drawers that well in any case, without a lot of waste space involved (IME anyway).
You may need provision to run a long molding or three. In that case, think about a sticking board which runs at right angles from your bench down the long axis of the space.
Light remains the biggest issue. There is nothing like natural light--if it can be had, provide for it. Get near it. Make the area light--light walls, light benchtop, everything light.
Wiley
Making use of a small space
