We value your privacy.
>How practical is it to drill end grain to a significant depth...say 14-18 inches?
I want to try my hand at building a flute. I know I can route a 3/4" to 1" diameter groove in two matching halves of wood and glue it together, but, for some of the woods I would like to try, I would prefer to have no visible line.
If drilling to this depth is practical using either an extra long bit or bit and extension, what kind of bit would be best? By hand (brace/bit) or using a drill or drill press? Woods would range from cedar to birdseye maple...very soft to quite hard.
You should get a copy of, or at least take a look at the Google Books copy online, of the book "The Amateur Wind Instrument Maker", by Trevor Robinson. It has the ISBN-13 number of 978-0870233128 and is available from a number of sources including Amazon. There is significant detail in this book about the endgrain drilling job you wish to do. Mr. Robinson even describes how to make the shell auger bit you need! Check out "Appendix C" for the details. The Google version is very incomplete - I have my own copy and it is a wonderful book.
Many years ago, I made the "cant rackette", shown on pages 69 and 72, out of cherry. A nearly impossible instrument to play - no wonder it went out of common use! Some day I wish to make a "cornetti" - a sort of very highly pitched, curved wooden trumpet.
Joe, you have to get this book! If you want to make a flute, this book is essential reading for wind instrument construction.
>I would recommend a nose auger or a quill bit, while those are hard to come by you can use a duck bill spoon bit (available from Lee Valley).
The size you need would allow a bit extension to be used as it will clear the hole. The spoon bits are not as big as you probably need, but once you get a through hole, reaming is an option.
Traditionally Native American flutes were split, hollowed and glued back together. Musical instrument flutes were turned on a lathe and the hole was turned or drilled with turning tools. The hole is through drilled then the outside turned to shape. The holes can be rough drilled from both ends and cleaned up later.
Maybe Lee Valley or someone else will come out with nose augers or spoon bits in larger sizes. A quill bit is fairly easy to make yourself.
>Shell auger is the way to go. Somehow, they manage to center themselves automatically in the wood as it spins... Miraculous! AND, exactly what you need.
