what is the angle to sharpen a frow
Wayne Carson
>I am making a frow and I need to know what is the angle for the bevel and is is sharpened as a single bevel or double.
any help appreciated
Wayne
Wayne Carson
Wayne
Re: what is the angle to sharpen a frow
Todd Hughes
>All that I have seen were double bevel and rather blunt...no need to have it real sharp....Todd
Dull as a frow.
Bob Hackett
>A froe is really nothing more than a thin splitting wedge with a handle attached.Look at a splitting wedge and then duplicate that edge properly proportioned to size.
The most important thing about riving with a froe is to use a proper club to drive it and a brake to both help hold the work and steer the split once established.
Drew Langsner,John Alexander,Mike Dunbar and St.Roy are excellent sources if info on tools and techniques for riving and green woodworking.
Mainely,Bob
ThomD
>I don't know what the angle is, so in that regard it doesn't maybe mater as one would discuss it with a chisel or plane bedding angle. I does mater though, and acute is what you want, other wise it will bounce and not penetrate. Lee Valley used to sell a froe that was just a parallel piece of bar stock with a blunt double edge on it. Very nasty wouldn't penetrate, at least not for the work I had in mind. The model they have had more recently was tapered pretty much from the top, like a shallow splitting wedge or axe bit. This one works very well.
My favourite is Drew Lansners. They are like airplane wings, with what would be the trailing edge on a wing, the cutting edge on the froe. The fattest portion is about midway or a little above, where a wing would be more lopsided than that. In a lot of ways not unlike the section of an axe head: Tapers to the cutting edge (no hollow in a froe), is fattest in the middle, and has a blunt edge for hitting along the spine. But you don't want the spine to be the fattest part or it is harder to rotate when levering. This kind of froe doesn't necessarily have a bevel right at the edge, it needn't be razor sharp, and the edge can be continuous with the form, convex, best sharpened on a belt sander, or with loose paper.
There may be different froe types. Some woods, say redwood for shingles, perfect grain, stiff, but very easy to cleave, may pop at with a small whack, and split right from the begining. The aspect ratio is also such that they are relatively stiff when popped off. So possibly a double edge with a 45-90 degree taper just sends them flying, or opens them up most of the way. Working woods that are much harder to split, much harder to start, and sections that are flexible relative to their length, required more the Langsner type of tool. The only problem there is they can be tool light, the section isn't as strong as a bar, so they need to be sized to the work, or heat treated.
Wayne
>What I got to make the thing is a piece of 1/4 x 2" leaf spring that is tempered and welded a piece of 1 1/4" pipe to one end. Was planning to bevel it like a almond shape but the top that you hit leave it as close to 1/4" as possible. I am using it to split wood to make wooden barrels and at the moment my love a butter churn as she needs more work ha I will tell her if I want her to know that. I have been trying to make some wooden bands to hold it all together and plain swan wood just can't take the stress making a tight circle. I got the plans out of a book called "Fox Fire" published in the 60's or 70's.
fox fire
Jack Guzman from Maine
>That is a great series of books. I have four of them.Full of much useful information as well as being very entertaining.---Jack
Two End Frows Rock!
