Not really a woodworking tool but...
>I have spent 2 years getting this tool in order. It is a tool for embossing wet leather leaving a row of connected S scrolls as it rotates. I beat the seller up on the price because it was froze solid.
I have tried everything to loosen the wheel. I soaked it with oil, I washed it with soap and water, I put it in an ultrasonic cleaner, I used Naval Jelly and repeated soaks in vinegar. I used dental floss to clean out softened rust, heated, froze and did everything but apply excessive force. I did address the slot but never put excessive pressure one way or the other.
I would work on it then sit it aside, then work on it again. Well after soaking in vinegar for several hours today, the screw moved just a little and then the wheel became loose. With a little coercion the wheel freed up and after cleaning a bit more it now works just fine.
It makes a nice pattern, I will use it to decorate the edge of a leather top on a lap desk I need to finish.
Sometimes it pays to be patient.
Stephen
Re: Not really a woodworking tool but...
...but from a related trade
>Neat tool.
Isn't it a grand feeling when you get something freed up that's been frozen by water and neglect, and bring a tool back to useful life?
todd Hughes
>I would have sprayed it with some good penetrating oil and then heated it hot with a propane torch popping it out of the handle if you had too and then some more oil as it cooled.
...From my experance I Would be very surprised if this wouldn't have worked and would probably only have taken 5 min.
Nice Roll....these were mostly used by Bookbinders. Older ones are normaly larger and will be intaglio cut where the background leather is pushed into the design....Todd
