We value your privacy.
>I'm about to make some cabinets for our bath remodel.
I know I could whittle a shelf-drilling jig, but am considering buying Lee Valley's because the setup looks pretty simple. Anyone used this jig and have some experience to describe?
>A friend was in you position, bought the jig and loves it. I found it slow to set up compared to my approach.
Being cheap, I drilled a bunch of guide holes (drill press) in a 7/8" x 2" x ?? length of poplar. I have several lengths. One 6' for closet shelves, and others shorter. I have drilled hundreds of holes with these simple devices, successfully. I do the drilling with a hand drill. The one thing to remember is to make sure you index off the same end each time.
One advantage over home made jigs is that the bushings won't wear.
The only complaint I have is that the hole guide rails need to be oriented correctly, they are not reversible. But now that I know this it isn't an issue and because it's precisely made one set up the drilling is fast and repeatable.
>I made several jigs for this purpose over the years. They are relatively easy to make. They also wear out when used much.
Several years ago I was faced with a few jobs where I needed to drill shilf-pin holes. Lots and lots of holes. I bought the LV jig. I would never make another unless I was faced with some odd-ball pin arrangement it would not handle.
4 or so years ago, I sold off much of the furniture making power and hand tools, jigs and accessories I owned. But some I held back knowing I would use them. This LV jig was one I kept.
not to take a sale away from LV but I have the Rockler Jig-it shelf pin template.It is an improvement over my previous method which was to use pegboard and a vix bit to layout holes 1" on center.The Rockler jig is repeatable and indexes along it's length.I have had no need to use or upgrade.The only thing I would like to buy is the different bits to allow the usage of different pins,but as of yet just the 1/4" has served me well.
Did you decide on which method/tool you are going to use?
I am in the process of a built in cabinet for a custom house and will end up drilling alot of holes for shelves.Still liking my Pockler jig and I am halfway done.
>I ordered the LV jig last night (and they've packed it already!).
I'm rationalizing it as the right decision because there will be four different, and tricky, cabinet depths in this project, and it looks to be a quick setup.
But, if I'm dead honest, the gizmocity attracted me too.
Oh well - I'm getting a deeply discounted HTC mobile base (currently on clearance) for my bandsaur on the same order, so I can pretend I'm saving money overall.
And, just to appease the hand tool gods, I'm getting a new LV iron for the sweetheart 60-1/2 I got last spring.
