Tool cabinet Dehumidifier installed!
Dominic in Buck's County PA
>Hi gang,
I finally installed the Goldenrod Dehumidifier in my tool cabinet today.
To recap: I was having re-occurring problems with rust forming on my hand planes. I had installed some of those anti corrosion emitters that LV sells. But IMHO they work much better in drawers and small spaces. Don't get me wrong, they work! I had a couple in my tool cabinet drawers and never saw an speck of rust. I think that the humidity in the plane tiill area was just too much for them.
A friend of mine who is into competition shooting suggested I look at Goldenrod Dehumidifiers. So I did and ended up purchasing the 1D12 model that is rated to protect 100 cu ft. Since my cabinet it just about 20 cu ft, I feel that this is more than ample.
In order to work properly, these dehumidifiers need to be installed horizontally, and at the base of the cabinet. Since my cabinet has a divider that cuts the inside in two, I decided to drill a 1 1/2" dia hole and have the dehumidifier span both cavities. I also drilled a corresponding hole at the top of the divider to help with the airflow. In addition to the holes, I cut the plane till door down by 1/2" so that it would have an additional 1/4" reveal at the top and bottom to aid the air flow.
In order to make room for the dehumidifier, I moved (4) of the planes in my plane till up along the wall. That really was the hardest part of the installation.
Oh and fishing the electrical cord down the back of the cabinet was a real PITA until I realized I could use one of those articulated magnetic probes to help me fish a cord through. BTW, this model features a plug that can be removed from the wire. That feature made this installation much easier. After that, it was a piece of cake.
The dehumidifier is to the lower right.
Here is a view from the other side of the divider.
And this shows the gap at the top and bottom of the plane till door.
That's about it. So now I'm hoping that I can open my tool cabinet and not get any "rust based" surprises! :>)
See ya around,
Dominic
