Veritas - Innovation in Tools
Trestle bench finished...
John Aniano - in Central NJ...
>Hello All,
Well, the new bow making bench is finally finished and in place in the new shop. I applied two coats of tung oil finish to the trestle base and butcher block top and when dry rubbed it out lightly with a 3M gray scotchbrite pad. The top was mounted using four 6" lag bolts with fender washers in very oversized holes in the top rails of the trestle side pieces to accommodate expansion of the maple top.
Next projects - finishing installing the shop window moldings, converting a Singer sewing machine base into a usable power source for my watchmaker's lathe and ... a Roubo bench...
John
Re: Trestle bench finished...
Wiley Horne--So. Calif.
>Beautiful bench and the light is going to be so good there. I admire your taste in saws also.
Wiley
John Aniano in NJ...
>Wiley,
The saw is just an inexpensive Zeta brand saw from Toshiro's. Good value and a well cutting saw blade. I've got the rip and crosscut blades and I especially like the flush-cutting blades they sell - I used them to cut off the draw bore pegs on the trestle legs. I'm a satisfied customer.
I'm just now having trouble finding their website - are they still in business?
John
Re: Trestle bench finished... Tashiro's  *LINK*
Tashiro's Hardware
wouldn't look out of place in a dining room
Bill Tindall, E.TN
>Pretty enough to eat off from (as they saw).
Jim Shaver - L6H 6Y0, Canada
>Hi John,
It is a pleasure to see your fine work again, the bench looks great.
I would like to see a post maybe in time once it finds it's place in your bow making, decked out in your tools and some bows, that would be wonderful to see!
Take care,
Jim
Just downright nice work!
Marv
Verrry nice John!
Joe Rogers, Northern Virginia
In case some have not seen... *LINK*
Dan Donaldson
>The link is to John's web page. He makes some exquisite bows. Take a look.
I would also be interested in seeing that bench fitted out and actually making bows.
John's website
wilbur
>Really nice job, John! That looks like a table you could sit down at for meals.
I really like how the wood looks after you finished it.
That's discusting...
Scott Burr in Ben Lomond CA
>Never before have I seen such a nice bench in a beautiful shop with great light and views. Oh yea, the floors great too.
Very nice indeed.
Since the question hasn't been asked ...
charlie belden
>- why leave the lag bolts and washers, as well as the barrel nuts, so obvious - and out of place given the rest of the bench? You've clearly got enough wood in the uprights to set the carriage bolts in deep enough to allow for a cap for the hole, same for the barrel bolts. Dome the caps for a button look if you think you may need to remove them for any reason.
The work you put in on this bench shows. The exposed lag bolt head and washer - even more out of place given its surroundings.
Re: Since the question hasn't been asked ...
Bob Hackett
>I thought the cad plated bolts looked alittle out of place on such a fine bench too.I`d be happy to see if bronze or stainless hardware could be had locally and give them a quick polish if you like the exposed hardware look.
Mainely,Bob
Michael Wilkins
>WOW!! Really nice. REALLY NICE!! This would fantastic in a kitchen with some minor height changes to the base. Almost too pretty to use.
LV Torsions Nuts *LINK*
charlie belden
>Or you could go with allthread and use these Lee Valley Torsion Nuts. If hardware has to show, these look sort of like sahllow domed ebony plugs. The inconspicuous holes in the side, in conjunction with the supplied steel rod, allow the nut to be turned - to tighten or loosen things if need be.
Lee Valley Tension Rod Nuts
Re: LV Torsions Nuts *LINK*
>Charlie,
Wow!! Those are purely good. Thanks for calling them out. Got to see if that 13tpi pitch will fit the thread on my LV cast-iron-leg bench.
Now, in John's situation, he might do something amazing if the spirit moves him. Below is a link to one gallery of his award-winning bows.
Wiley
Bow Gallery II (of IV)--John Aniano, Bowmaker
Bows
charlie belden
>Followed the earlier link - and was quite impressed, both with the desigs as well as the woods and craftsmanship. And musicians really appreciate fine quality - especially in their bow if they play a bowed instrument. Lots of engineering in those things. Making it look beautiful and elegant as well . . .
WITH LV Torsions Nuts
charlie belden
>Tweeked the original picture in PhotoShop to see what it'd look like with the LV Torsion nuts and plugs for the barrel nuts
