A Plane from Matjiesfontein *LINK*
>A little story on my website.
Link below ..
Link below ..
Re: A Plane from Matjiesfontein
Bob Hackett
>I have an almost new 2 1/4" Sandusky laminated tapered iron and chip breaker in my hand that you can make fit if you want it.I could also paw around in the basement looking for a 2 1/8" but I may have to bring food and water if I have to go too far back(To say it`s a mess is HUGE understatement).
Mainely,Bob
Stuart Hough
>Nice catch, Derek!
Neat and interesting
>What I find really interesting is that, if you'd presented that plane as one of your own, I'd have said, "Oh, yes, another Derek Cohen beauty." I wonder how much your adult tool design sensibility comes from tools you saw as a youth and folded into memory without realizing it.
Wiley Horne--So. Calif.
>Great story, Derek! How could the world be so small, after all?
And a very handy size plane, too. Looks like a Jr. Try to me--for flattening and straightening all those short sticks that occur in every single project.
I'll say one thing for that Mathieson iron--it's given good value. Are you going to use it right down to the slot? After that, it could be used to cut twin mortises maybe....(<:).
If you have a tough time finding a 2-1/8" replacement, someone there in Perth with a water jet cutter could trim down a 2-1/4" blade set clean as a whistle, and give you back two 1/16" strips in change. [Konrad had a 2-1/4" blade cut down to 2" that way, and I"m still mulling over what to do with the two nice 1/8" strips of 3V he sent (with the finished plane).]
But mainly, it's a great story. Do you remember the voyage from So. Africa to Australia?
Wiley
Hi Wiley
I reground the hollow to 25 degrees (it was 35 degrees) and sharpened it up, adding a camber for moderately thick smoothing shavings.
It took good see-through fine shavings at first, but as I thickened them up the mouth began to clog and finally the plane stopped working. It took a little while to work out that the wedge was too long and trapping the shavings. Once I shortened it by about 1/4" and reshaped the end, it began to perform as I hoped.
It should be a good plane to use after my jack.
I am going to use the blade as long as possible. The steel still seems hard.
Wiley, I've been in Australia going on about 26 years. It feels like forever. The decision to leave SA was political - at the time Apartheid was still enforced and did not appear to be diminishing. In fact the country had just completed an election and the government was returned yet again. Lynndy and I had fought this immorality for so long but we just could not see ourselves doing so forever as this meant raising a family in this psychological climate. There was the constant risk of being imprisoned simply for speaking out against the government. I had graduated and completed a couple of years in practice, and professionally the future was bright. I applied for and was offered a job in a prestigeous hospital in Sydney, and we essentially left with the shirts on our back but hope in our heart. We have never regretted leaving save for the fact that we left family behind. I still return to see my folks every year. We embraced Oz and have built a wonderful life. My outlook is very Australian. My values are very Australia. I am very Australian. But I have not forgotten my roots.
Bob Demers
>Derek
That's an interesting plane you got there. My first impression was that it look too new to be old, almost look new construction, laminated construction to boot. But the markings on it lend it a air of age, and the well used up iron....
So im guessing it was recently restored. Very shiny, no grime, pristine sole, which may explained why the wedge was now a smidge too long.
Nonetheless, that plane is surely priceless to you because it provides a link to your past. And that my friend is indeed very cool
Bob, where the temperature are quickly dropping, snow anyone...
odd
paul womack
>I don't think I've ever seen a 4 layer laminated body before;
Either a single join down the middle (which allow easy tool access) or laminated cheeks, but not both!
Perhaps the guy had cheap access to a given thickness of timber.
It looks like he also had access to some kind of guide for letter punches; the letters where clearly used separately (since they don't line up precisely), but are nicely stamped, except on the wedge, where the top of each letter is deeper than the bottom.
The condition is remarkable - it's certainly seen little use, or the wear would be evident. There is a question over wether it's been cleaned up for sale; is there any evidence of dirt in the corners near the handle Derek?
The worn-out blade is a mystery - the only answers that occur to me is either the guy made the best plane he could with a free blade and free timber , or that the plane had a GREAT blade, which has been swapped with an old Mathieson from the spares drawer by someone in the sales chain.
But certainly an item of interest, Derek.
BugBear
Re: odd
>Hi BB
I agree the construction is most unusual. I doubt very much that this plane was built by Matheson. It is likely shop made. I also am unsure whether it is new or old. It looks new rather than re-finished.
I don't care. It is a great memento and, having tuned it up, it works superbly.
