Have a question? Ask Woody!
Strike Block / Miter Plane
>I took all of the advise and modified the plane. In particular rounding the back top of the wedge (Thanks Rob Lee) exposed the blade making it much easier to adjust.
The top of the throat was sharp on the fingers when using it on a shooting board, so I cut a cupids bow to take care of the sharp end grain edge. I also relieved behind the throat and sprung the wedge.
It works well on hardwood, softwood, flat grain, end grain and on the miter. I am also using it a lot more like Moxon described by holding it upside down and passing the edges of boards over the blade.
I oiled the plane today and will put it together in its 'finished' state tomorrow.
Stephen
Re: Strike Block / Miter Plane
Wiley Horne--So. Calif.
>Nice going Stephen! I didn't notice til this picture, what a fine block of wood went into that plane. Look at the ray fleck on the left (upfacing) side. Beech or maple?
Wiley
>Wiley,
It is some scrap 2"+ maple from a friend of mine. I have several pieces that I intend to turn into small planes of various angles. I have enough left from this piece for two more planes. I didn't cut it to length until the throat and mouth were formed, so I had something to clamp down to the bench to make the plane. I put a piece of scrap pine under the mouth to save my bench.
Not as rough as a Krenov and not as fine as a Clark & Williams, but good enough for me.
Stephen
>Stephen,
The plane has a presence. My first thought was it was maple, because of the real fine small ray fleck on it--that's something I always like about maple.
I use my woodies upside down, too. Not trying to do reenactment (after Moxon)--it's just an intuitive way to use a woodie for fine fitting. It puts the work up in your eyes so you can see tiny details. And the plane is light and handy, so it's natural to do it. Not just for miters, but also real small work like cleaning up stringing after you cut it off the veneer stock.
It's a very useful thing you can do with a woodie.
I'm curious to hear your impressions on the low angle bedding. Can you feel the difference on end grain, compared to 45-50 degree planes?
Wiley
Stuart Hough
>Stephen, please forgive my neophyte-ness, but it looks like you did this from a solid block of wood, not a cut-and-reglue as in a kit. How long did it take and how difficult was the process of exposing the plane that was hiding in that block of maple? I'm extremely interested in making a few planes for myself in the future, so your insights will be greatly appreciated.
Victor Parisian
>Hi Stephen (or anyone else with an answer),
First, I like your strike plane a lot, and the carved bow-tie is a very nice touch.
Where did you get that great blade? Looks very old.
The body of the plane looks like you carved it out of a solid block. Is there a reason this couldn't be constructed out of a single block with the sides ripped off and the remaining center block cut into the front and back pieces and then glued back together? I imagine that a jig of sorts would have to be cobbled together to assure reasonable alignment of the pieces during the glue up.
I would think that the resulting frog area and mouth could be made more accurately than carving (at least in my hands anyway). Since I have yet to make my own plane maybe the obvious is going over my head here.
I have the piece of maple ready for a trial run at this.
Victor in Houston
I'm not Stephen, but...
Chuck Nickerson
>The construction method you describe is often used, and works. But in Stephen's woodworking he hews as closely as possible to how things were done in the Great Salt Lake basin in 1850 or so.
Chris Friesen
>" Is there a reason this couldn't be constructed out of a single block with the sides ripped off and the remaining center block cut into the front and back pieces and then glued back together?"
None whatsoever. This is actually how a "Krenov-style" plane is made. As for a blade, the replacement blades for the Lee Valley "taiwanese-style" planes are quite reasonably priced and are by all accounts excellent blades.
Thanks to both of you.
Victor Parisian
The iron
>"Where did you get that great blade? Looks very old."
Hi Victor,
Not Stephen, but am sure he'll be along directly. Stephen uses and is a proponent of laminated (laid steel) irons. He described that blade on his (fullchisel.com) blog some time ago. He had searched and searched for a laminated blade, and then came across that blade at Galoot Tool.
It's actually a new blade, but hammer forged by a smith in China. It's tempered on the hard side. Derek has tested one of these blades, and had good words to say about it--perhaps he can elaborate if he sees this, or provide a link.
Wiley
I am mainly going to use it on a shooting board, miter shooting board, side rest and mules ear (when I make another one). It is much cleaner a cut than the 50 degree I had been using. I made a couple of mahogany triangles (for plane making) using this plane and the cuts were nice and flat and glass smooth.
Stephen
>Stuart,
I am not a fan of that type of plane, not that traditional and there are problems with a glue up on tools like this. Unless you use Hide Glue the other glue will creep. There are also problems with moisture movement, aesthetics, etc.
I chose to chop out the mortise and use a brass pin to capture the wedge. The low angle is the only reason for this. If I do another low angle, it will be lower and bevel up.
Stephen
Re: The iron
>Thanks Wiley,
The blade really is the plane. This laid steel blade from Galoot Tools is one of the finest things I have ever had an opportunity to have in my hands. My plane is nothing without this blade. It has mass, the steel is dead hard and the backing can be eased with a file.
It is keeping its edge and I have been doing some flat planing on pine with knot holes. Higher angle plane would be a better choice but I had to experiment. This tool is really for end grain and miter work. I use it on a shooting board, miter shooting board, bench hook as well as cradled in my hand held against my chest for small work. I will have to give it a try in the miter jack.
Stephen
Re: The iron
>Stephen,
How is that blade to sharpen? Are you using oil stones with it? I am guessing it is a very clean steel.
Wiley
Different topic *LINK*
>Stephen,
Thanks for the info. on the effect of low angle.
Different question. I was looking at your blog earlier today, trying to find your entry on the Galoot Tools blade. Didn't find, but I did come across your photo of Brigham Young's tool box! Link attached. Here's my question: Who made those tools? It's eating me up who made that screw-arm plough. It has very distinctive nuts on it--they look like a Hills & Winship I have. Are you able to get any closer to those planes, or perhaps the archivist has noted markings on the tools.
Wiley
Stephen's 'Full Chisel' blog--Brigham Young
Re: Different topic
>Wiley,
I have actually been given permission to catalogue and publish a monograph on this tool box, I just haven't got around to doing it yet. So as of present there is no record of the tools other than a rough description. Hopefully it will be one of my projects this winter.
Stephen
Re: The iron
>Wiley,
The blade came from Galoot Tools sharp and flat no evidence of a round wheel being used. The steel is very clean, very hard and holds an excellent edge.
As for the stones I use, washita and arkansas and and English slate for the finest grit followed by a leather strop. I suppose they are water stones because I use them dry and clean them with spit.
Stephen
