Seen it, but don't know what I'm looking for...
Joe Pack
>I am out of my league on this board, but figure someone here will know enough to help me out. I (think) I have seen what I am looking for, but don't know what to look or ask for.
The tool has a handle like a screwdriver or chisel, but has a curved cutting edge that looks like a "C" shape, or even like a "C" that is almost closed into a circle. I want to use it to hollow out the openings in two matched pieces of wood or stick to form the inner barrel of a flute.
Again, I think I have seen such an animal in the past, but don't know enough to know were to look. Can anyone steer me in the right direction?
Thanks for bearing with a novice.
Re: Seen it, but don't know what I'm looking for...
Do you mean a gouge? *LINK*
>If I understand your question correctly, I think you're talking about a gouge - see link below.
If this is what you want, you can get them from Lee Valley, Tools for Working Wood, Woodcraft, or other sources - the companies I listed by name are Wood Central sponsors, and, if you go to the marketplace and follow the link to the company from which you order, WC will get some advertising brownie points.
Some Lee Valley gouges - lots of other sources
No...
Joe Pack
>No, not a standard gouge. Imagine a knife that has a blade that looks like it has been bent around a pipe...the blade is bent almost into a circle instead of flat. Only one edge is sharpened. It appeared that the tool is pulled to form a groove. I don't know if the tool is a standard one or was homemade.
This? *LINK*
Dean Lapinel
>This??
Scorp
crooked knife
Alan Schwabacher
>That sounds like a crooked knife, a traditional native American tool. They exist with lots of different curves, depending on the purpose. If you google that, you will find descriptions and instructions for making them, but I don't know where you can buy one.
Some like ...
>... an apple corer?
In wood ...
... and silver ..
Something along the lines of the latter? It would be a gouge then, I suppose.
Or Hook knife or hoof knife
>Alan was correct.
If you have a hard time finding one, they are available at any Farm Supply Store and are used to clean the hooves of horses. You can get them either left or right hand.
A trick when using it is to use it on the skew, it cuts better but tends to pull to one side.
After contact with Europeans this was the preferred tool for making flutes, etc. by the Native Americans. Prior to that a knapped stone scraper would have been used.
Stephen
Re: Seen it, but don't know what I'm looking for.. *LINK*
Chuck Nickerson
>Lee Valley (and others) carry a hook knife. North Bay Forge used to make smaller ones (down to 3/16" diameter), but he's stopped.
Hook Knife
Re: No...------ *LINK*
KenI------
>hmm.. hook knife? This is what I found with a quick search....
http://www.pinewoodforge.com/
That's it...
Joe Pack
>The scorp and/or the hook knife are what I have seen. Thanks to all. Now I know what to search for, and also have a few sources.
