Progress on tray
Bill Tindall, E.TN
>as a reminder this is what I am trying to make, more of less...........
Progress on tray
Bill Tindall, E.TN
Step one done, raw materials for sides
Bill Tindall, E.TN
>There are 26 separate pieces assembled into what will be this tray end. First, the light/dark banding was glued up like a butcher block and the banded veneer sliced off at about 1/8" thick. This banding strip was next glued to a backing about 1/4" thick. These elements comprise the center section of the assembly shown. The top band is a 3-ply plywood by 3/8" thick, which I was told would be more robust for fretting. It was vacuum pressed. A 1/2" wide strip is then glued on the bottom. Once the glue is hard I will thickness sand these side assemblies and start cutting the fretwork. The target thickness for the sides will be 5/16".
There has got to be a simpler way to make these parts!
whoops forgot PIC
Bill Tindall, E.TN
Dang, That's a lot of work...
Scott Burr in Ben Lomond CA
>Hope it all goes well Bill! Thanks for the update and keep up the good work!
3 fret holes cut, 177 to go...........
Bill Tindall, E.TN
And the current count is?
Victor P
I am embarassed to say........
Bill Tindall, E.TN
>but it is more than 3.
