Plane finished *LINK*
>Well it is not quite finished I will do some more work but it is in working order.
Thanks to all who helped me place the pin, it is in the center of the overall throat length. I happened to have a 1/4 inch diameter piece of brass that seems to be working just fine.
I will probably profile the upper edges a bit more, round over the back more than it is and might do something fancy with the throat on top.
It doesn't clog even though the wedge goes down to within 3/4 inch of the blade, the wedge is too long and I will thin it out a bit and shorten it on the thin end.
Stephen
Strike Block Plane
Re: Plane finished *LINK*
Tasty, Stephen
>I will be interested to see how you shape the block to suit your hands and your comfort level. Also, what kind of mouth opening does this beauty have? I see your test shavings are really thick. What will be the intended use for your plane, delicate final passes or somewhere in between rough and final?
Good work.
An from the peanut gallery...
Pam Niedermayer, Austin, TX
>What does a strike block plane do?
Pam
Re: Plane finished
Wiley Horne--So. Calif.
>Stephen,
Very nice low angle plane! I really liked the looks of that Galoot Tool laminated iron. Did you bevel the iron at 25, or lower yet?
Is the wedge flat bottomed, or is it sprung under the pin?
Thanks and congratulations,
Wiley
Re: Tasty, Stephen
>Ellis,
It has a loud mouth (read big mouth) and I intend to use this plane for end-grain and miters as well as flat grain. It seems to work well when I tried in all cases. It was set fairly coarse for those shavings, I backed it off for end grain.
I also had to use a file to soften the back sides of the iron as they were sharp from the manufacturer. I may do some more work to it but it is a user not a looker.
Stephen
Re: An from the peanut gallery...
>Pam,
A strike block or straight block plane is just a low angle plane used for shooting miters. Most are made bevel up, mine is bevel down.
Stephen
Re: Plane finished
>Hi Stephen
I think you have done a successful job with the placement of the cross pin. Overall it is looking good already. I look forward to the finished plane.
I have the same Galoot Tools iron in one of my planes, and it has been excellent - gets very sharp and hold the edge well.
Re: Plane finished
>Wiley,
The iron was ground 25 degrees from Galoot Tools and mounted bevel down. Also the blade was provided sharped and it was good out of the box, although it was wrapped in paper.
It is flat on the underside of the wedge. (Now that you mention it I may hollow out the back of the wedge.) I do plan on shortening the wedge to access the back end of the blade, so I can smack it with a hammer. There is some denting on the wedge, it may cause a problem.
Stephen
Re: Plane finished
>Derek,
Thanks, the pin is placed half way in the overall throat measurement. The blade is excellent and has real heft.
Stephen
Then why not call it a miter plane?
Well then it is a Miter Plane
wilbur
>"A strike block or straight block plane is just a low angle plane used for shooting miters."
I think that I am being way too literal, but is there any difference between shooting miters and shooting a square edge? Are there different planes for each task?
Re: Plane finished
Ace Karner
>Great looking plane Stephen, have you thought about a handhold of some sort on the top side? Some kinda tote that would fit in the web of the thumb maybe.
Nice paint job!
Alan DuBoff
>Stephen,
Really nice job, that pine looks exactly like maple.:-)
Cheers,
Alan
Craig D
End grain (miter) and long grain (square edge, as in jointing)?
Craig
it's just traditional jargon
paul womack
Re: Plane finished
Rob Lee
>Hi -
Great looking plane - very clean!
Only suggestion I possibly add, is that you may want to consider docking the corners off the back/lower edge of the wedge...or even just rounding it over.
As a Brit would say - I'll bet it "works a treat!" ...!
Cheers -
Rob
wilbur
>I meant shooting a square edge on end grain, like what you would do after making a crosscut.
Re: Then why not call it a miter plane? [LONG]
>In the absence of historian Don McConnell, I'll give you my two cents. Generically, the strike block is a miter plane, but it is a specific kind of miter plane. Also, as Paul says, the terminology has historical reference in Moxon and elsewhere, and so the term remains with us.
Whelan, in The Wooden Plane, discusses the strike block on pp. 62-63. The strike block was the last of the bevel-down wooden miter planes; there was an intermediate bevel-up wooden plane, dand then after a time the bevel-up metal miter won out. It is worth mentioning that bevel-up metal miters were in use in Germany back into the 1500's--Josef Greber shows photos of some surviving ones, with highly ornate metal work.
Wilbur asked about the distinction between mitering angles and end grain shooting. Here is what Moxon (1703) says. If you want to sing along, refer to Chris Schwarz' Moxon book, p. 25. Moxon says: "The strike block...is a plane shorter than the jointer, having its sole made exactly flat and straight, and is used for the shooting of a short joint because it is more handy than the long jointer. It is also used for framing and fitting the joints of miters and bevels, but then it is used in a different manner from other planes. For if the miter and bevel you are to fit be small, you must hold it very steady in your left hand with the sole of it upwards, and its fore-end towards your right hand, and you must hold your work in your right hand very steady. Then apply the sawn miter or sawn bevel at the end of your stuff to the fore-end of the strike-block and so thrust it hard and upright forwards until it passes over the edge of the iron. So shall the edge of the iron, with several of these thrusts continued, cut or plane off your stuff the roughness that the teeth of your saw made. But if your work be so big that you cannot well wield it in your right hand, you must set the end of your work in the bench-screw and plane upon it with a smoothing plane."
Chris Schwarz gathers from this, and I agree, that Moxon is talking about shooting short long grain joints (because the shorter plane is handier than a long jointer), and also for 'framing and fitting' miters and bevels. Moxon doesn't answer Wilbur's question, so perhaps he is including all end grain cuts--angled miters and end-squaring--in the same description. The interesting thing is that this work is done freehand. No shooting board is in sight.
Moxon shows a squarish plane, like Stephen's, with no tote. There were American models with totes, like the Dominy strike block shown in Whelan, p. 63. John Aniano made a beautiful strike block, much like the Dominy one (perhaps an intentional copy?), several months ago on these pages.
Yours truly was most pleased to receive a C&W strike block a few months ago, bedded at 40 degrees. I believe John Aniano's was low angle as well. Stephen's plane at 30 degrees should be an exceptional end grain cutter, and I would suggest that he scrape the sole just behind the mouth--with the iron fully tensioned--to eliminate the possibility of a bulge there, due to the very low angle of the plane, and the iron being pressed down upon somewhat thin support.
Wiley
Are metal miter planes bevel up or down?
Re: Are metal miter planes bevel up or down?
>Hi Pam,
Bevel up and low bedding angle. Historically, they tend to be bedded at around 20 degrees, give or take. Lie Nielsen's modern one (No. 9) is bedded at 20.
Wiley
>This strike block is bevel down at a relatively low angle (25� according to Stephen in a message below). And yet it's intended to do miters? I guess I'll try to find Whelan and read all about sb's and miter's; but right now it's all too confusing as to why one is called one thing or the other. So far I'm feeling quite superior and above all this by virtue of using/making Japanese style planes that look the same without the wedge and do the same job, as well as some others. :)
Pam
Re: Plane finished
>Ace,
I don't intend to put a tote on this plane, I can get a good grip in the throat when I use it for shooting with a shooting board or side rest.
Stephen
It is so seldom
>that I get to work with hardwoods. I make all of my furniture of pine and paint and grain finish.
The only time I seem to work with hardwoods is when I make tools.
Stephen
Re: Plane finished
>Rob,
Now that I look at it, I see what you mean. I will shorten the wedge to expose the end of the iron and dock off the corners of the wedge, thanks.
It is a treat to use, can't wait until next week when I will get a chance to put it to the test.
Stephen
