ADVERTISE HERE - FREE TRIAL
Age of Tree
Age of Tree
Age of Tree
John L. Blue
>I've got a 50 ft. Water Oak in the yard, has a 5 ft. circumference, wonderin' how to tell it's age without cutting it down and countin' the rings? Appreciate it in advance.
Re: Age of Tree
Re: Age of Tree
>You can have a core taken which will indicate the age of the tree without cutting it down. This has to be done by someone with the proper tools and training. Tree core augers are interesting tools.
Stephen
Re: Age of Tree
estimate
Bill Tindall, E.TN
>If you can find a similar tree that has been cut it is a good guess to presume your tree has grown at the same rate, which would be 1/2" diameter per year in good conditions, more under ideal conditions like in a yard with little competition. 50 years old or less will likely be close.
Re: Age of Tree
Re: Age of Tree
Sgian Dubh
>If the girth is 60" a rough guide is to count a year's growth per inch of girth, ie, 60 years. This assumes that a typical tree in temperate regions increases its diameter by approximately 9 mm (3/8") per growing season.
I have found this rough and ready system reasonably accurate for I have measured trees where the date of germination can be ascertained to within a decade or two due to particular historical records or knowledge of the site, eg, known dates for enclosure of a field with a hedge when measuring a hedgerow tree, etc.
However I've found a tree needs to be about 30 to 40 years old before this rough and ready method works to any degree of usefulness, and I can't say for sure how accurate the system is outside Great Britain where I live and where growth rates may be quite different due to climatic differences and species variations. It works pretty well for most of the common trees, eg, European oaks, European ash, beech, maples, birch, etc. Slainte.
Re: Age of Tree
Re: Age of Tree
DaleLenz
>Estimating a tree age with out having other trees, age known, of the same species and growing on the same site is going to be nothing more than a guess. Pin oaks are relatively fast growing oaks as are a few other oaks in the red oak group: water, willow and Nuttall to name a few. A lot of folks call pin oaks water oaks/willow oaks and visa verse.
Around here, in E. Oklahoma a 19" DBH pin oak on a good site with low competition would be 25+ years old, MY GUESS. How old is the house? A starting point, chances are the tree was planted by one of the house owners. Have 3 Nuttall oaks in my yard that was planted from a one year old seedling in 1995(?) and without measuring the DBH, I'd guess them to be 9-10".
As Steven said an increment borer is a handy tool to pull out a core sample so you could count the growth rings, don't for get to add a few year for the tree to of reached the height of the sample. Usually, increment samples are pulled at a convent working height of the tree, say DBH, diameter at breast height, 4.5' above the ground. On a good site for a pin oak, I'd add 2-3 years.
If you know of a forester or call your county foresty office and they might volunteer to core the tree. I try not to core post oaks around here as I have broke two bits off in them, over a $100 each.
Hope I have helped
Re: Age of Tree
If you core it...
Martin from Texas
>plug the hole when you are done.
Use caulk or something like it.
Pines will plug the holes with pitch, hardwoods can use a little help.
