Have a question? Ask Woody!
New bench construction - some electrons expended..
John Aniano in central NJ...
>Hello All,
About 3 weeks ago I decided to make a new workbench dedicated to making bows. It is for my new shop space on the 2nd floor of a pole barn we had built about 2 years ago. The 32' x 12' shop space is finally taking shape - the white oak floor is done and the window moldings are almost finished and installed, so workbenches were the next logical step.
Last year, as part of the Central Jersey Woodworkers Association "Big Wood Buy", I had the chance to get several large planks of what I thought was red oak with the idea that they would one day become benches. That time had come.
I cannot take credit for the basic design of this bench. That credit goes to Morgan Andersen, a bow making friend in Rosalia, Washington. I adapted Morgan's design (below) to the stock thicknesses I had. I also made the new bench larger. And although I describe the construction of the trestle base below, I cheated and bought a 24"x60" maple top for my new bench.
I got out my trusty Husquvarna chain saw (yes, I said there were power tools used in this project! But hey, the end result is for hand tool usage so I guess it is OK). The chain saw made fast work of crosscutting the planks of "oak" to rough length. In fact, the chain saw cut too easily and at that point I realized this was not red oak. At first, I thought it was ash, but later realized chestnut was a better candidate. The planks were very old, and so encrusted with barn dirt that they were literally brown/black. Even a few scraper passes made me think "oak". Anyway, the wood was easier to work with than I expected. I bucked out lengths for the trestle tops, bottoms and vertical members. The stock was a true 3" thick at this point but needed to be cleaned up. Once ripped on my bandsaw, the narrower pieces were surfaced on a 6" jointer, and trued up and final surfaced with hand planes.
I marked out the curved feet on the bottoms with a can of paint as a pattern and cut them using the bandsaw. I cleaned up the surfaces using, of all tools, my little Stanley #92 rabbet plane. It did a great job in the corners as well as the curved sections.
I marked out the mortise and tenon joints and drilled out the waste with a 1.5" Forstner bit. Squaring up and cleanup was with a 1" chisel.
The 2" long tenons were cut by hand using a modified tenon saw (teeth shaped as rip teeth a la Mario Rodriguez) and a conventional crosscut tenon saw. Clean up of the tenons was with a Mattheson 1-1/2" wide rebate plane. I drilled out the 5/16" dowel holes in the tops and bottoms and marked the tenons using the same brad-point drill bit. I offset the holes ~1/16" in the tenons to drawbore the joints.
White oak pins were made by pounding them though a steel plate with a 5/16" diameter tapered hole. After final surfacing all the members one final time, I beveled the edges with a #102 plane. Glue up was with my favorite Kremer liquid fish glue. With the joints assembled, the pins were driven in and pulled everything together. I let the pieces dry overnight and trimmed off the excess pins with a Japanese Zeta flush cut saw and planed the ends flush to the sides.
The stretcher was really of oak, white oak in fact, and quite hard and heavy. Surfacing this was a challenge since the piece was ~8" wide so I enlisted a neighbor who has an old Craftsman surface planer. I cleaned up the planer marks with hand planes. There was, however, a knot that had badly chipped out on one edge, so I needed to address that. A bevel would have hidden it, but thinking out loud, I felt that a small OG moulding would look nicer. I have a nice Sims moulding plane and this worked well on the corners of the white oak. The knot chip-out was hidden. Don't let folks tell you that old molding planes can only be used on soft woods - when properly tuned up, they can work on hard woods like white oak. They don't like it, but they can perform well.
Some of the tools used include the Mattheson plane, a Spear and Jackson tenon saw and a Richardson Bros. tenon saw with rip teeth.
Using a corded 1/2" drill, the holes for the Veritas bench bolts were bored out. I used the drill press and a forstner bit for the 1" holes for the round Veritas nuts in the stretcher.
Here is the assembled trestle base in it's new home in my new shop space. Another installment will show the finishing of this bench. Stay tuned.
John
Re: New bench construction - some electrons expended..
An enjoyable description, thanks for posting
Bill Tindall, E.TN
Handsome bench
Wiley Horne--So. Calif.
>John,
That is really an appealing design! What's the right benchtop height for bowmaking? Also, what kind of work-holding appliances do you use for bows--hands only?
That workshop space looks might inviting too--light and open. Where's all your stuff gonna go, though? Rolling tool chest beside bench?
Thanks for sharing, Wiley
Re: Handsome bench--P.S.
>John,
Meant to thank you for the draw-boring data--data is always scarce and as a result highly appreciated.
Is that a 4" thick top??? Hell of a find! 2-1/4" is the best I could find commercially.
Wiley
John Aniano - in NJ...
>Wiley,
Thanks for the kind words. Unfortunately, my bench will only have a commercial 1-3/4" butcher block top. My friend Morgan's bench does have thick top - I'm sure he glued it up and was about 3"+ thick. I'll have final photos of my bench with the top in a few days - when the tung oil dries.
I've made my bench 33" tall. I sit at the bench mostly, but do some planing standing up. Mostly, the bow "bits" are held by hand while being worked. One gets a self-leveling effect if the work and tool are allowed to float together. This tends to keep flat surfaces flat.
There will be a front "bench block" of maple screwed to the front of the bench when finished. I'll take it off of my current bench (in the small cramped shop). It facilitates some of the frog and pearl slide work. The block also holds some of the removable items like a curved bending form and rehairing string.
I've collected a number of small wooden tool chests in the past few years, so the bow making tools will be in a wooden tool chest, probably sitting on the bench in the back. I keep the small knives and chisels I use in a cigar box also on the bench.
John
Dan Donaldson
>John, if you ever get the time, I would love to see a set of in progress shots of making a bow. That would seem to be something with unique requirements and the process would be very interesting to me, and I am guessing others as well. From some of the pictures that you have posted, you do some beautiful work and it deserves a bit more exposure. ;-)
Joe Rogers, Northern Virginia
>Good work there John. Post updates as possible and I too would love to see it in use at some time!
Joe
