My first hand cut dovetails!
Dominic in Buck's County PA
>While I was waiting for the glue to dry on a practice hand plane blank today I decided to once again attempt to cut some dovetails. Before I started I remembered a thread on WoodNet and the neat parring jig that Hank Knight & Derek Cohen had made:
Learnin to cut dovetails
So I looked through the scrap bin and came up with some appropriately sized pieces of wood and made one. Well, the rest is pretty evident. The jig really helped me to parr a nice straight edge. I was able to make a very nice set of dovetails in a short time. They are not perfect, but I'm just so overjoyed that I was even able to get them to fit!
Photobucket
See ya around,
Dominic
Re: My first hand cut dovetails!
perspective
Bill Tindall, E.TN
>The original objective of dovetails was to hold something together, not brag on the perfection of their execution. Yours will do nicely for their original function. Go forth and use them to advantage.
I fear that the fixation some have on flauntable dovetails may dissuade others from using this useful joint in their furniture.
Victor Parisian
>Looking good Dom.
I'll have to check out that jig. I've been doing mine rather hit or miss lately. Yes, my latest dovetails are holding a drawer together, but they are a tad sloppy, but as Bill said, they are serving the function well. I should have spent a wee bit more time squaring thinks up. While all my corners are spot on 90 degrees, it doesn't quite sit flat. I forgot the third dimension.
Enjoy
Victor
Hear, hear
>When we cleared out my parents' place, I found a nineteenth century chest of drawers, and you could just about wedge a Siamese cat into the gaps in some of the dovetails.
I drool over the perfect dovetails, too - but recognize it'll be some time before mine can approach Dominic's.
Wiley Horne--So. Calif.
>Those are tight, Dom!!
I really encourage the use of a paring block. The crisp scribe line which results made a large and immediate improvement in my dovetails. I use about a 2" x 2" hard maple block. They're easy to make--the only thing that requires real attention is getting the block truly square down its length.
The one other thing I would mention is to put a sacrificial piece of plywood on the base above the work. Otherwise, you will soon be needing a new base, as the chisel will quickly dig a trench where the paring block meets the base. This will not just chew through your base, but also will result in ragging of the bottom side of the work, since the chisel will be exiting the cut into thin air as the base gets chopped up. So use sacrificial ply under the work--one sheet will last a long time, because you move it around to keep solid bedding under the work.
Dom, are you sure you didn't practice a little before doing that one!!??
Wiley
there is an easy prevention for this problem
Bill Tindall, E.TN
>I too had problems getting long drawers to lay flat, especially if they were not very tall. Now I mark the pieces as follows. I assemble one corner of the drawer on a flat surface, table saw for example, using a piece of angle iron in the corner and C-clamps to hold the corner together with the aid of the angle iron. If the tails(or pins) are marked in this way the drawer is ensured to be flat because the planer table makes it so. Additionally, it is easy to mark with the drawer corner clamped this way. Once clamped the assembly can be picked up and oriented for easy marking.
Have you ever forgot to make one of the necessary lines? Using other marking techniques I never could precisely reorient the drawer corner for redoing a mark. With the angle iron arrangement the pieces can be precisely repositioned if necessary.
Philip Duffy
>Good job, Dom! Phil
Jack Guzman from Maine
>Hi Dom,
Those are some nice first dovetails. It is a fun joint to make.One of the interesting things about dovetails is that you can approach them in different ways.When making drawers in most projects,functionality is the only real priority.You want to hold the drawer together as efficiently and neatly as possible.Any fancyness(is that a word?)is unnecessary.As long as the joint is done correctly,it looks good. However,if you are making a piece that you know will be judged artistically in every square inch,you can get creative with this functional joint.There is always discussion on overly obsessing on this joint but there really is room for both ways of thinking.Rob Cosman made a DVD showing some fancy dovetails. Though I haven't tried them yet I mean to as soon as I find a project that will be good for them.
Enjoy---Jack
Dominic in Bucks County PA
>Thanks for the compliments Wiley!
The idea about the sacrificial base is a good one. I'll root around in the scrap pile and see what I have that'll work. Maybe some 1/4" plywood?
And to be brutally honest, I've saw cut dovetails at least 5 or 10 other times. But each time I screwed it up. You know, taking out the pin side instead to the waste side! I can't count how many times I've done that. LOL! But this was the second or third time I actually got to the point where I was able to parr to the line.
Re: Hear, hear
>Thanks Bill. But what you can't see are the gaps on the rear.
I realize that this is a joint that is meant to hold two pieces of wood together. And I don't want to get all hung up on perfecting it to the point where it looses it's use.
I'm just so damn happy that I ws able to cut them and they FIT! LOL!
Shoot the ends
Hank Knight
>Nice dovetails, Dom!
I never really got my drawers flat until I started shooting the ends of drawer sides until they were dead square before I marked them with the gauge. Just a tiny bit of out-of-square will throw the drawer off noticeably, and it's almost impossible to pull it back to square. If you start square, you end up square.
My $.02.
Hank
Amen
roninkokomo
Re: Shoot the ends
>Back in my power tools day when i was workign with my leigh Dovetail Jig I learned the folly of NOT having square ends on my workpieces. Since then I check all boards and end up shooting the ends
And since I got a LN#9 (I just love using that bad boy!) and made a shoot board I shoot all the items I cut. I look for an excuse to use it!
wilbur
>NIce job, Dominic! They look better than mine.
pretty close...fanci�ness n.
Victor Parisian
