Rusty old anvils
Rusty old anvils
Moses Yoder
Rusty old anvils
Moses Yoder
>How would you go about cleaning up a rusty old anvil? It is a Peter Wright, I think 100 pounds. It says 0 3 .25 on the side. The top is no longer flat in the center, it has a hollow in it probably from pounding on it over a 100 years or so. I doubt it is worth much but means a lot to me because it was my grandfather's. I have some Gibbs oil that I was thinking of applying with a rag and then leaving it soak for a day or so before scrubbing it with fine steel wool. What do you think? It set in a barn for the last 30 or 40 years with absolutely no maintenance.
Re: Rusty old anvils
Alan DuBoff
>The numbering systems is for hundred weight, so the first number equates to 112 lbs, the second number to 28 lbs, and the last in pounds. So your anvil is 109 lbs, ((3 x 28) + 25).
There are various way to clean them, I've used electrolysis on one before, it worked ok if you have a large enough tub, I used a trash can.
You could also use a wire wheel, that would be ok as well.
Aside from that just use kerosene, elbow grease, and a scotch pad.:-)
To answer your question, the Peter Wright anvils were wrought on the bottom with a tool steel plate on top. If you look along the edge up near the top you'll be able to see the tool steel plate, I think many were about 7/16" thick.
I had a beat up PW 134, but sold it finally...I have 2 Hay Budden anvils now, they are some of my favorites, the later ones are 1/3rd tool steel.
Peter Wrights are good anvils, noted for being loud ringers, so consider using a sheet of lead under it, chain wrapped around it, or magnet(s) on the side, any or all of the above will keep the ringing down.
I don't mind the noise much myself, and learned on a Peter Wright with no noise mufflin', that anvil would sing a song like you never heard!
Cheers,
Alan
Hank Knight
>Moses, I don't know squat about anvils, but I'm glad you got your grandfather's anvil. Good for you! Enjoy it.
Hank
Wire Brush
David Miller from Iowa
>I have cleaned/rehabilitated a number of anvils and I just use a stiff wire brush first and then some oil - WD-40 comes to mind, but pretty much anything will work. A wire brush on an angle grinder is nice, but go easy - the even patina can be lost easily. A little sag in the anvil is fine, if the sides are mushroomed just grind them off with an angle grinder.
Trade-off
David Cockey
>Before doing much, decide what you want. Once metal is removed you can't put it back. Restoration to "like new" can look nice, but it may no longer look or feel like your grandfather's anvil.
Yay! Glad you got it!
Amen!
Wiley Horne--So. Calif.
Philip Duffy
>Moses, What about grinding the top flat and putting on a new top of a nice shinny steel. Would that not make a complete anvil for modern use? Phil
Todd Hughes
>Might be easier said then done. I have seen a few anvils that had had thier tops replaced the guys that did it said they were fine but I don't know. I tried one out befor and it was horriable being very dead. Apparently the problem is welding the steel plate so that it is attached all over the top of the anvil and just not on the edges. Supposedly to do a good job you should drill holes through the plate and weld it through these holes...don't know. I do know I would not let just anyone do this job.
....Many people like Peter Wright anvils but in my experance you see lots of them that are sway back like this plus they are very noisy
... A sway back anvil might be good enough if you are doing rough work but to do anything else you need a flat anvil and it shouldn't have a pitted rusted top either
If my anvil I would just knock the rust off with a wire brush and paint it with some old motor oil and let it be at that...Might be tempted to paint my grandfathers name on it but would probably set down till that desire passed....Todd
I have this vision.....
Bill Tindall, E.TN
>of your anvil sitting in a large electrolysis bath hooked up to your battery charger and bubbling away the rust. Somebody once call me to ask if I would consult for them in building an electrolysis bath to do antique tractors. The anvil seems trivial by comparison.
Yeah, I'd like to see a pic...
Alan DuBoff
>David,
You have a good point, and a pic might help to see what the anvil looks like. Certainly, an anvil can be usable and doesn't even need to be cleaned, it will get clean as you forge on it, but all that will get on your work as well...in order to be usable not much is needed, even if it is not flat. You can use a belt sander on them to get them pretty flat, I did that to the one I had...
But, before doing anything, how about a pic?
Often they end up painted, and I think that is disgustingly fugly. That is why I put mine in an electrolysis bath. I like an anvil cleaned and oiled, but everyone is different. I like it oiled on the sides also, not painted, because I use the side of my anvil and I don't want paint on anything I'm working hot metal. You can upset into the side of the anvil.
If you really wanted to fix the sway, you could weld rod into it and grind/sand it flat. You'd be surprised what a good smith can do in that regard. Consider what you will do with it before you invest too much time and effort into it, it might serve itself well being in your possession just knowing it was your Grandfather's.
But David makes a good point in that you might not think of it as your Grandfather's anvil if it changes.
Have you tried it out with some hot metal? Do you have a forge? Try forging some type of trinket that reminds you of your Grandfather.:-)
