paint spatter
paint spatter
Jack Guzman from Maine
paint spatter
>This has probably been asked many times but if so I'm unaware of it. Does anyone have any tips on how to remove old paint spatter(small dots of color)from an antique finish without affecting the finish?
I run into this alot with old clocks.I buy beat up rejects and rehab them.Repair movements,add missing parts,remake missing moldings,that sort of thing.One I have now is a Banjo style,early 1900s,with a beautiful finish.The wood is dark with some painted designs.The finish is clear and has an even crackle throughout it from age.
At some point in the clock's history,some careless person did some painting wherever the clock was hanging(or laying) and got spatter all over the front of it.There are about 40 varying sized specks of blue paint on top of the finish.I'd like to find some way to soften the paint so it peels off but I'm afraid to leave marks in the finish.I tried a little alcohol on a rag in an area that can't be seen and it didn't seem to dull the finish any,but that won't remove paint. Any ideas?---Jack
Re: paint spatter
Gojo
David Miller from Iowa
>Gojo Hand cleaner really works well and, for some reason, doesn't touch the original finish. I just restored a Delta scroll saw that had been repainted with paint over the badge and Gojo took it right off and left the badge like new.
Re: paint spatter
the problem....
Bill Tindall, E.TN
>There are numerous possibilities for the clock finish and each will respond to solvent differently. And, there are additional possibilities for the paint formulation with their response to solvent. Bottom line, there is not universal fix that involves softening the paint and not affecting the clock finish. Tediously scraping the dots off with a razor blade may be the only universal fix.
