"Lightweight" metal spokeshaves
>There's frequent mention here and other places, whenever the spokeshave question comes up, of the Stanley/Record/others Nos. 51/52, 53/54, and 151 (I guess there was a 152 also, but it must be rare). I haven't seen much mention of the lightweight shaves, such as the Stanley 63 and 64, but these are worth watching for. These are like the No. 52, but differ in being smaller, with a narrower iron, and in some other details.
My first lightweight shave was a Kunz round-sole - round in the sense that the sole is curved front to back. It seems most of us own a Kunz tool at one time or another, and, for most of us, it seems to be a lesson in what not to do with the next tool purchase. It was for me. I was never able to make that thing work; it always chattered like a squirrel on espresso, and I ultimately donated it to some rummage sale or other (so that someone else, or perhaps successive someone elses, could have the same useful life lesson it had offered me).
Later, though, I picked up a 64 (top tool in photo below), which is a flat-soled shave along the lines of the 52, and found it a pretty decent tool. Note that the cap sets flat on the iron, held down by a thumbscrew, and that the cutting iron is designed to slide out the mouth (you can remove the cap iron and then the cutting iron as you would with a 52, but sliding it out the mouth works fine).
Late last month, on impulse, I bid on the Stanley 63 round-soled shave shown at bottom in the photo, and won it at $8.50. I expected to find the same chatter problem as with the Kunz, but have been delighted to find that it cuts pretty smoothly, and, in common with other round-soled shaves, gets into tighter corners than a flat-soled shave (by the way, it seems to be happiest being pulled).
If much of your spokeshave work, or intended work if you don't own one yet, involves chamfers on curved stock or cleanup of 4/4 stock, it's worth looking at these tools, as they're often below the eBay radar (except, of course, for collector-grade examples). There are some issues, addressed in my next message, and someday I need to get around to learning how to embed photos in messages.
Re: "Lightweight" metal spokeshaves
Some issues
>These shaves were cheaper than their larger counterparts - 17 cents for a 64, 30 cents for a 52 in the 1914 catalog, for instance - but production costs were probably only marginally different. It's pretty clear from the examples I own that Stanley felt it had to cut corners to make a profit, and did so through its quality control.
On both shaves, the portion of the casting that forms the mouth is mildly warped backwards, so that the mouth opening is less in the center than at the edges; less so on the No. 63 than on the No. 64. Cutting irons are rather thin, and on the 64, thickness varies at the end opposite the cutting edge; in fact, when I first got it, I thought it was a cheap knockoff, discovering only when I sanded off the rust that it's a Stanley of the 1874-84 era, based on the logo. As the photo below shows, the maker's stamp was rather sloppily applied to the Sweetheart era No. 63.
In spite of these quality control issues, I have found them productive tools and think they're still worth considering.
Darrell in Oakville
Darrell in Oakville
>I like those little shaves. They work well, better than their bigger brothers in many cases. I've been collecting them for a few years now, and have enough to keep the Scout Troop busy... Here is a shot of some of the collection, there are a few more around someplace.
Darrell
Dan Donaldson
>I have a small metal shave that is about 8 3/4 wide with a 1 3/4 blade. It has "union mfg co" and "new britain" and "USA" stamped on the blade. The handle has 118 cast into it. Any idea what it is?
Darrell in Oakville
Darrell in Oakville
>Sorry Dan, apart from the obvious response, all I can suggest is that you clean it, sharpen it, and use it.
I do own a few Union tools but they all appear to be Stanley knock-offs. Good tools, but still knock-offs as far as I can tell.
Darrell
Sounds a lot like the Stanley 64
Dan Donaldson
>I figured something like that, just wondered if anyone knew what it was. I have flattened the sole and sharpened it. Has a fairly wide mouth, but seems to work ok.
