Re: Tormek question, Derek and others
wilbur
>Hi Wiley,
I've got a Tormek that I mainly use for my turning tools. For my straight edged tools, I use it mainly for getting rid of nicks or resetting the bevel angle.
The jigs that come with the Tormek are fine for chisels and plane blades. I don't think they will cover skew chisels, however. There is a jig for skew chisels (SVS-50). For gouges, it depends the type of gouge you have, and how long the tool is. The short tool jig (SVS-32) is probably the most suitable for carving gouges, and the gouge jig (SVD-185) is mainly for turning gouges.
As has been mentioned already, there are some things you can do to optimize the Tormek for removing a fair amount of metal. Retruing the surface and setting the Tormek up so that the wheel is turning towards the tool is key for this sort of operation. And the water cooling allows you to grind continuously without worrying about heat buildup at all.
One time I was involved in a discussion on how slow/fast the Tormek is for restoring a damaged edge on a tool, so I timed how long it took the Tormek to repair a chisel. Here's what I posted in that discussion:
And to be absolutely clear, I do not think that a Tormek is faster than a dry wheel grinder by any means. I just wanted to measure how long it takes me to fix up a tool with my Tormek.
So first thing to do get the Tormek as optimized as it can be for removing larger quantities of metal. The best way I've found to do this is redress the stone wheel. This picture will show that I'm just as bad as anyone about letting the wheel get loaded up with metal as anyone, and may be a big reason why some of us are reporting results that are slower than what we would want.
The next thing to do is find a victim. I have one antique plane blade that could use refurbushing, but it doesn't really have a nick -- just a bevel angle that is much too shallow for my taste. So I decided to sacrifice a 3/4" Marples chisel. I took my chisel and banged on the concrete floor of my basement, and various other hard objects to try to get it dull.
I put the chisel into the straight edge jig (the older one), set up for a 25� bevel angle, and started grinding with the wheel turning towards the tool. I used a fair amount of pressure on the tool. This is what I got after about 2-1/2 minutes.
So all the nicks were gone after just a few minutes. Of course, one might argue that this isn't a huge amount of damage. So I decided to mess up my chisel some more. This is what I did to it:
Japanese chisel vs. western chisel. This was the outcome:
These nicks are about 1/16" deep. I set up the jig again, and this took me about 4 minutes to do:
I then used the fine stone conditioner on the wheel of the Tormek to convert it into a finer grit stone, and got this in about 30 seconds:
And I get endgrain shavings off of Douglas fir like this:
Now, normally I would take the tool from the rough grinding stage and go to my waterstones to hone an edge.
Again, I want to emphasize that I don't think that this is faster than using a dry wheel grinder, and as was mentioned above, you should use the tool most appropriate for the job. It just so happens that I don't have a dry wheel grinder. Some may also think that the amount of time that I spent on these operations is too long, but I can live with it.
At least we now have some numbers to discuss. 4 minutes for a 1/16" nick. Extrapolating, that's 8-10 minutes of Tormeking for a 1/8" nick.
