Sheffield, 1879
Don McConnell
>As Joel has already mentioned, the term "Cast Steel" refers to the use of crucible steel in the manufacture of an edge tool. The term "cast" being derived from the fact that the steel was poured, or cast, from the crucible to form ingots. These ingots were then rolled or "tilted" (power hammered) into bars and rods in preparation for further manufacturing processes.
Since confusion on this issue seems to be somewhat common, I thought it might be useful to type in text, below, from an 1879 Sheffield publication which describes the forging process of edge tools in some detail. (Incidentally, the book is available through Google Books if anyone is interested in reading more of it.)
Hope this helps clarify this issue.
Don McConnell
Eureka Springs, AR
_The Illustrated Guide to Sheffield and the Surrounding District_, edited by John Taylor, � 1879, pages 267 to 269.
"EDGE TOOLS."
"The manufacture of light and heavy edge tools, and other joiners' tools, is also a considerable industry in Sheffield. The variety of these tools is very great, including chisels, gouges, augers, gimlets, plane irons, braces and bits, squares, levels, spokeshaves, hammers, axes, adzes, hedging and other bills, hatchets &c., &c.
Some of the tools, moreover, are made of many sizes and shapes. In gouges, for instance, there are no less than seven different "sweeps" or bends, and each bend is made of twenty different sizes, making 140 varieties of one simple tool. The amount of detail in the trade is consequently enormous, and the sub-division of labour is proportionately great. The forgers work in pairs, as in the table knife and heavier branches of the file trade - a forger and striker in each shop - and the two are kept as far as practicable to one class of work - often to a few sizes of one tool - in which they acquire great skill.
In the shaping of tools, "prints" and "bosses" are much more largely used than for table cutlery or files, and in much greater variety of size and shape. These articles are, in fact, moulds, into the recesses of which the pliant metal is crushed by the hammer while red hot, instead of being poured while in a liquid state, as in the making of castings; and the process is called "mooding" (moulding). As previously mentioned, one side of the dies or moulds, known as "prints" or " bosses," consist of a small square block of metal, and fits into the anvil; but the other side, which is held in the hand during use, is hammer-shaped, and has a very primitive handle, formed by twisting a twig of hazel round it, and fastening the two ends together with a ring.
Special dies being required for every variety in the size or shape of the tool to be made, prints and bosses form an important part of the furniture of an edge tool forger's workshop. The walls of workshops in which the smaller tools are made are often almost concealed by rows of these implements, carefully arranged according to size and pattern, the set for a single shop costing �40 to �50. To this explanation of the simple means by which apparently difficult ends are attained, we must add that though the forging of edge tools does not differ in principle from the forging of cutlery and files, the greater number and complication of the processes occasion a much larger amount of labour.
Take, for instance, a common joiner's chisel, which is one of the most simple of edge tools. The forger heats the end of a rod of steel selected to size; roughly shapes the blade; cuts it off with sufficient for the bolster and tang; re-heats; shapes the bolster with prints, and draws out the tapering tang with the hammer. The blade is then re-heated, and carefully "plated" (hammered out) to the size and shape required, water being thrown on at intervals during the brief process to remove scale. Gouges are forged in the same way, the blades being afterwards rounded in "hollowing bosses."
The forgings then pass into other hands to be hardened, tempered, ground, glazed, and "finished," ready for packing. The more complicated socket chisel passes through the forger's hands no less than six times; is then hardened, tempered, set, ground, glazed, japanned, and finished, passing three times through the hands of the grinder in the course of these operations. �"
