Rabbet Plane *LINK*
Rabbet Plane *LINK*
Rabbet Plane *LINK*
Bob Henderson
>Generally, when I see a wooden hand plane at a local antique or consignment shop it is either warped, split, or has some other terrible flaw but I picked up this Marples rabbet (rebate) plane up for $16. The sole is close to square to the sides and almost dead flat front to back. There is a slight convexity across the sole at the front, but it flattens out as it nears the mouth. The only flaw I can find is the wedge is split slightly, but when it is in use, the split is forced shut so I don't think I need worry about that.
I'm a hand tool newbie, especially when it comes to wooden planes, so I have three questions (follow the link below to see more pictures).
1. Was $16 a reasonable price for this plane?
2. Approximately how old is this plane?
3. Should I try to get the sole dead flat and square to the sides or can I use it successfully as it is?
More Rabbet Plane Pix
Re: Rabbet Plane *LINK*
Re: Rabbet Plane
>I think $16 is reasonable, but I'm not an expert on woodies by any means. Consider that, if you'd purchased it on a certain online auction site, you'd have had to pay shipping; this way, you didn't (though maybe you have a stiff sales tax in your area, which would offset that advantage).
As to your question #3, sharpen up the iron and try it out. Problems with out of flat sole or sides will manifest themselves as you do. I think we sometimes obsess far too much on flatness in these tools.
Re: Rabbet Plane
Wiley Horne--So. Calif.
>Hello Bob,
On the $16, I think you did OK for retail. And skew rabbets don't show up in yard sales.
The main thing is, the plane looks pretty sharp. That is a wonderful block of beech, absolutely dead quartered, close grained, and from your photos, it's still square. Being English, it's bedded 50 degrees (not 45), which is a plus for figured wood.
Another thing to like about the plane is that the blade looks to be in real good shape. It appears to have its original bevel, like it wasn't used and sharpened much. Furthermore, the skew of the blade lines up real well with the skew of the sole. So you're not going to have to regrind the blade, or adjust the skew, to get it going again. Looks to me like sharpening is all it needs.
You mentioned the crack in the wedge. For right now, don't do anything. If that crack starts to run, you can suck some liquid hide glue (cause it's nice and thin), or else yellow glue, up into a 20-gauge syringe, and inject it into the crack, and that will make it sound.
You can retract the blade by hitting the butt of the plane at a 45 degree angle with a non-marring hammer--don't need to tap back on the wedge finial, like someone has been doing.
On the age of the plane....one of the main experts on this subject is Don McConnell, who by the way makes great use of rabbet planes in his latest DVD on Cornice Moldings. Anyway, Don once told me, or else published online, the information that the suffix 'England' wasn't added to the mark until the early 1900's. Prior to that, it would have just said 'Sheffield', and left it at that. Perhaps someone has specific information on Marples marks, and can pin this down further.
As Bill Houghton said, just sharpen and use the plane for a while. From the photos, it's in good enough shape as is, that it will be dicey whether your adjustments will make it better or worse. Also, technique is important in getting a square rebate cut. The thing to do right now is use the plane as is to make a few rabbets in soft wood, and check them with a square. Get your technique right, and go from there.
It looks to be a sound and useful plane, in a beautiful block of beech, and a lightly used blade. Sharpening is the main skill needed at present.
WIley
Gluing cracks
>"...you can suck some liquid hide glue (cause it's nice and thin), or else yellow glue, up into a 20-gauge syringe, and inject it into the crack..."
Another trick I learned from some magazine or other, if the crack runs all the way through, is to put some white or yellow glue on one side of the crack and apply the end of a shop vac hose (running vacuum...) to the other. It will snork the glue right through the crack.
Of course, if it's a clean crack, it's sometimes easier to finish the split and reglue after coating both sides; depends on the circumstances.
Clamp with rubber bands; the kind that come on broccoli are very good for this size of project.
Three cheers for broccoli rubber bands!
Marv
>Sometimes, if it's an old crack, it will have dirt in it and the glue will not hold. In those situations, I saw the crack out, being careful to leave a nice even uniform kerf. Then I cut a thin piece of new wood and glue it in and clamp it. Or a Broccoli rubber band..yeah!
When you fit the thin piece of new wood in the kerf, it should easily slip in and out of the kerf. You will want to smear glue down in the kerf and on all surfaces of the thin piece of new wood. The glue swells the wood just a bit, thats why you want it to slip easily into the kerf before applying the glue.
Marv
Here's an example of fixing cracks by sawing them out. In this case, no clamping was required.
Re: Three cheers for broccoli rubber bands!
Ace Karner
>It's really neat how gluing all those pieces of wood in the sawn out cracks makes the repair look like it's got some great wheat carving. :)
Marv
>Ace,
I like to say...."if'n ya cain't gloat, why do it?" *grin*
Marv
Re: Rabbet Plane
Bob Henderson
>Thank you all,
The crack does go all the way through, so Ill try the shop vac glue trick. I'll figure some way to clamp it - personally, I'd rather buy rubber bands than have to eat broccoli.
I'll sharpen up the blade and have a go. It is a beautiful hunk of wood, although I thought it was oak, it has that fleck pattern that you see on arts and craft furniture made of quartersawn red oak.
Bob H.
Now Marv...
Scott Burr in Ben Lomond CA
>You're being predigest. Asparagus, Leeks, and all kinds of other vegies come with a rubber band.
8^)
Re: Rabbet Plane
>Don't use modern white or yellow glue or you will effect the value of the piece. Use Hide Glue, either hot or the easy to use liquid form and it will not detract from the value.
I always stare them down on the price if a tool has been glued with modern glues and I always greatly increase my price to repair old furniture that has been repaired with modern glues.
Stephen
Joshua Clark
>Bob-
That looks like a good, usable rabbet plane. For $16 I'd say it's a reasonable deal for a good, user-grade plane. A skew rabbet like this is a very useful plane. You can use it in place of, or along side a metallic plane like an 073. They are really useful for cleaning up or tweaking a rabbet left behind by a combination plane or electric router. That's where I use mine the most. You can also set them to take a very rank cut and make quick work of most jobs. That's something I won't do with a combination plane. Almost all rabbet planes, whether American or British were bedded at 50 degrees. With the skew blade, higher bedding angle, and the mass of the body behind it, they usually give good results on just about any wood.
Your plane has a couple of things going for it that will make it easy to rehab into a usable plane. It has a sole that's square to the sides and the back of the blade doesn't appear to have any pitting. Two things you want to check: First, make sure that the body isn't twisted. That's the kiss of death for planes with this type of escapement like dados and rabbets. It's also a common defect since there's so little wood holding together the front and rear of the plane. Also, make sure that the blade projects evenly across the sole of the plane when the iron is set even to or just a 1/1000th past the right side of the body. If the blade doesn't project evenly, it won't make an accurate rabbet. If the blade already has the proper geometry, don't grind a whole new bevel when sharpening it, just polish the back and put a new microbevel on it and you'll be ready to go.
I added a link to a video I put together of a tuned skew rabbet plane in use. They are great planes to use.
Hope this helps.
Josh
Deomonstrating a Skew Rabbet Plane
