Saw storage in tool cabinet
Dominic in Buck's County PA
>Hi gang,
This past weekend I completed the saw storage portion of my tool cabinet. Back last year at this time I had installed my old stock of saws on the left side door panel. Along with them I had marking knives and some other assorted tools.
Here's a photo showing the old configuration on the left hand door panel.
Photobucket
Fast forward a couple months and add some saw acquisitions. I got a Wenzloff Small tenon saw for my birthday, a Graymercy Dovetail saw, a small jewelers coping saw, and I made a 12" bow saw. So I ditched the plastic handled Cobalt (Lowes), shelved the rusty old Warranted Superior Dovetail saw (I still plan to rehab that, but later), as well as my old Crown Gent's saw (which was as sharp as a bowling ball).
Another thing that prompted me to change the way I stored my saws was the way that my Dozuki and Dovetail saw were stored promoted rust. The wooden blocks that the blades sat in seemed to hold moisture. I had to keep a constant eye on them for fear of them getting rusty. That got old FAST.
So I took all my saws and laid them out on the empty door panel. Here's a shot of the layout.
Saw layout on panel
Nothing was mounted on the right side panel. So I decided to move all the saws to that side and then use the left side for the rest of the tools I wanted to store (ANOTHER project).
These panels are really "sub panels" that fit inside the doors of my tool cabinet. The reason I made them this was was to avoid making my door panels look like Swiss cheese when I screwed up drilling holes. And I KNOW I would do that. So I just designed that problem out of the mix.
So after arriving at the ideal layout, I took a photo and proceeded to make tool holders for the saws that didn't have them already. I've always had this thing for the clever way that the tools in the Studley Tool Cabinet were locked in place. So I took that idea and made french fitted holders for the saws.
Here's a close up of the top portion
Close up of saw holders
Here's a close up of the bottom
I wanted something that would secure the saws and stop them from bumping into one another when the door was swung open. But I wanted them to be easy to get out as well. Some like the jeweler's coping saw and flush cutting saw are held in my gravity. Others are held in by a set or retainers with a wooden toggle. Some of the wooden toggles even got a stop made so they wouldn't drop out of place. Like I said, I want them secure.
All of the holders were made from various pieces of scrap wood like walnut, claro walnut, pear, cherry and hickory. They all got a coat of Danish oil and were installed on the panel via screwed from the rear side.
New Saw Storage door
Also made a holder for my eggbeater drill and mounted this under my braces. The door panel to the plane till is perfect for this.
Brace & Eggbeater Drill Storage
The best part of this project was that I pretty much used handtools for everything! The curves were cut with the bow saw, the parts shaped with a rasp and the holes were drilled with a brace or eggbeater. I did however, user my cordless drill to mount the holders to the door. It's sort of impossible to try to use a brace on handed!
See ya around,
Dominic
Re: Saw storage in tool cabinet
Paul Kramer
Beautiful, Dominic
Paul Kramer
Jim Shaver - Oakville, Ont, Canada
>Simply OutStanding Dom,
Love it!!
Take care,
Jim
Stuart Hough
>Dom, everything looks great! And what's more, it now makes more sense to group everything by job (i.e. sawing, marking, boring). Keep up the good work!
Nice collection and nice work
>There's a Shop Shot if I ever saw one. Thanks, Dominic.
I'm guessing that the saws pivot on a pin
Victor Parisian
>Can you elaborate on your set up there? Is it the right side or left side and how much clearance did you allow. What keeps it from crashing into the saws mounted on the door?
Curious minds need to know.
Victor - In Hot and Humid Houston
Re: I'm guessing that the saws pivot on a pin
Dominic Greco in Bucks County Pa
>You wrote:
"Can you elaborate on your set up there? Is it the right side or left side and how much clearance did you allow. What keeps it from crashing into the saws mounted on the door?"
not sure I understand the "left side right side part". But the double doors are over 3" deep so there is plenty of clearance between the saws and the actual cabinet.
>Thanks for the compliments everyone!!
Victor Parisian
>Ok,I think I see pins in the upper right corner of your picture with the braces. Is this a panel that pivots out to reveal the saws behind the panel?
more details please.
Victor
wilbur
>Hi Dominic,
That cabinet of yours looks really great!
There's one issue that I see with your storage for the dozuki. It looks like that the dozuki is resting on its blade at the bottom, which might lead to bending of the blade. Usually, Japanese saws are stored using a slot cut in a piece of wood so that the flat part of the handle is resting on the wood, and the blade hangs freely.
I'll take a picture of how I have my Japanese saws hanging up and post it tonight.
>Look at the center of the cabinet in the photo below. That door that the braces are mounted to covers my plane till. Here's a photo with the door closed:.
Photobucket
Here's one with the door open and the planes exposed.
Photobucket
>Wilbur,
Yeah, you may be right about that.
But I'm thinking that the clamping mechanism of the toggle holds it pretty securely. So not all it's weight rests on the blade tip.
Beautiful. thanks for t;he clarification.
Victor Parisian
My Japanese saw rack
wilbur
>Here's a shot of how I store my Japanese saws. They sit on a scrap piece of what used to be a 2x4, with slots cut into it on a diagonal, to help them sit closer to the wall. Some of the slots are wider than the others to accommodate the replaceable blade holding mechanism, or the steel back of the dozukis. They rest on the handles, as you can see.
My Japanese saw rack - closeup
wilbur
>Here's a closeup shot of how the handles of the Japanese saws rest on the 2x4.
My suggestion would be to reconfigure the toggle so that your dozuki handle rests on it in a similar manner. Those blades are really thin, and you don't want to introduce any type of bend in it.
Re: My Japanese saw rack - closeup
Pam Niedermayer, Austin, TX
>I agree with you. I've been using several of those magnet bars for Japanese saws, and wince every time I grab one at the potential bending. Those magnets are stronger than they look. I prefer your solution, hadn't thought about slanting the slots.
Pam
Today is the day Derek finally lost it. :@)
wilbur
>I never thought that someone who obviously knows, recognizes, and can do fine woodworking would consider a hand dovetailed tool cabinet outfitted with hardwood fixtures upon which to hang his saws to be "philistine" compared to my 2x4 glued and screwed to the wall.
maybe he feels guilty
Bruce, a MN Galoot
>because he has holes instead of dovetail slots in the handles of his saws :-)
bh
He's embarassed
Alexander Grigoriev
>...because he made the wrong-way dovetails!
yabut
Bruce, a MN Galoot
>even my right-way dovetails don't look as good as his wrong-way ones.
bruce, still working on them in MN.
