Re: Veneering with hide glue
ThomD
>I don't think a foam roller would be the ticket, the glue is pretty hot, and can pull back. The typical glue brush is sorta like a bunch of bamboo strands or some such in a bunch, even a brush will get tired pretty quickly.
I made my hammer out of a piece of 3/16" brass stock let into a wooden head, and epoxied in place. I filed the edge round, though a lot of flat stock is pretty nicely rounded to start with.
The hammer sets the glue in two ways. It narrows the bond line down so that very little heat or moisture is left and the glue sets up on contact. The metal sucks some heat out of the glue so that it sets, this is why a metal hammer is prefered, and a metal like brass with good thermal mass and conductivity.
The instructions I read originally said to paint glue on both sides of the veneer, because the glue on top would help the hammer slide around and hold more heat. seemed to work, but I don't know if it is all that useful. Larger pieces really do need some ongoing heating. I use an old iron, and start at some point, usually the middle, but it could be an edge with a book match. I start rubbing it out, but it quickly starts to set. It takes some feel to add the heat where you need it without releasing adjascent pieces that one already had down with minimal glue holding them. But at worst you can start all over again. The first project I tried turned out fine, so I think it is pretty easy and forgiving.
