A55 Smoothing Plane
Router Plane blades(attn:Rob Lee)
Jack Guzman from Maine
>I just finished creating a 5/16" thick stub tenon mortise in the rail of a frame and panel door.I always finish these by leveling out the bottom with my LV router plane with the 1/4" blade(bit?)in it.I was thinking that it would be handy to have a 5/16" size for my router.It would be useful for all kinds of operations.
Anyone else feel this would be useful,or is it just me?
Rob: Has this ever crossed your mind? Would it be practical to manufacture such a tool? You could sell it as an optional accessory to your router plane kit.---Jack
Re: Router Plane blades(attn:Rob Lee)
Rob Lee
>Hi -
Good feedback to have - but most likely a problematic size...at least, short term.
You see, our large blades are two piece, and 5/16" wouldn't leave enough material to use a two piece design.... so that means to make a 5/16", we'd need a new forging die, which is pretty expensive.
Narrower (from 1/4") would be easier to do though, and that too, is on our list...
If you really want a 5/16", a good solution may be to pick up a 1/2 Stanley (forged) blade, and grind it down to size....
We're just in the process of redeveloping our blade manufacturing (new grinding equipment etc.) so we should be able to address an expanded range soon....
Cheers -
Rob
>Rob,
Thanks for the response.I just may modify a stanley.Meanwhile I'll be looking for the smaller sizes.---Jack
